Rated vs. Actual Power & Volume Control
alucididea
in Electronics
So, I’ve got a question concerning power.
Let’s say an amplifier is rated to 300w RMS (20-20000hz). Now let’s say my speaker is only rated to 250w. Volume control goes from -80 dB to +16.5 dB. At what volume level would it actually be safe to use this amp/speaker combo?
I’m figuring as long as I don’t turn it above, say -20 or so? Any input would be welcomed.
60% of the time it works every time.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Use your ears. When it sounds bad, turn it down. If you feel technical then buy a Sound Pressure Level meter so that you can put a number on what you hear. Of course, this assumes you have ‘normal’ speakers that will let you know they are hurting.
Three 20 amp circuits. -
My thoughts exactly.*note 78% of all statistics are made up on the spot*
I agree with that. I guess I’m trying to create a general rule of thumb for myself.Use your ears. When it sounds bad, turn it down. If you feel technical then buy a Sound Pressure Level meter so that you can put a number on what you hear. Of course, this assumes you have ‘normal’ speakers that will let you know they are hurting.
The problem, to me, is that volume controls have different meanings in different setups. A number in one setup doesn’t necessarily relate to another setup.Lumin X1 file player, Westminster Labs interconnect cable
Fair enough.The problem, to me, is that volume controls have different meanings in different setups. A number in one setup doesn’t necessarily relate to another setup. -
alucididea wrote: »Volume control goes from -80 dB to +16.5 dB.
I would ignore the power (unless it’s clipping). The volume control suggests your preamp is able to calibrate to reference levels. At common THX levels -20db on the volume knob should produce around 85db from the speakers. This is a normal listening level and doubt you would be overdriving and pushing more than a few watts. If you know what your speakers maximum output db is it would be relatively easy to derive the max volume level and compute the power.
- Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
- Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
- Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
- Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
- Office-2.1 B&W Formation Duo and Bass
- Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
- Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
- Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
- Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
- Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
- Maintenance: Pro-Ject VC-S Record Cleaning Machine
