SDA SRS 2 + GFA 555 = WOW!!
JayMX
Finally found a bigger amp at a reasonable price for the SDA's. Holy ****!! That is all...
Current Collection: Monitor 4a (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), Full mod SDA CRS 4.1TL (198’s), SDA SRS 2.3TL, R100's, R200’s, R300 🤩
Amazing what a little current will do...
I’m considering it a Father’s Day present to myself!
Current Collection: Monitor 4a (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), Full mod SDA CRS 4.1TL (198’s), SDA SRS 2.3TL, R100's, R200’s, R300 🤩 -
I always thought the soundstage was impressive before, but it’s just amazing now. Channel separation is very impressive! Dead silent when it’s idling. Also, even at low levels there is a “meatyness” that I never experienced before. I am really amazed by this old gal! Love it!Current Collection: Monitor 4a (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), Full mod SDA CRS 4.1TL (198’s), SDA SRS 2.3TL, R100's, R200’s, R300 🤩
So you got a Clean Adcom GFA-555 original Nelson Pass AMP?
txcoastal1 wrote: »
You sure about that?
Old 16th August 2002, 11:06 PM #2
Nelson Pass is offline Nelson Pass United States
The one and only
Adcom 555II - Nelson Pass ?
I designed the 555. I believe the Mk II added a couple
of what were considered improvements, and it seemed
to me that it included triple darlington outputs instead
of 2 follower. I might have the schematic around, but
all told it was a simple bipolar design with a current
sourced input diff pair followed by a common-emitter
gain device that was also current sourced. This drove
the followers.
It was typical of all the 5XXX amps that I did the first one
and then they improved it until it had too many parts,
and then I would design the next in the series
Americo Borza sent me an old 555 in the hopes that I
would update it, and it still sits here, a perfect candidate
since so many of them were built.
Personally, I would score a few of these and run them till
they die and then update them. If you wait long enough,
an update will be issued. -
It amazes me that there are so many amp designs still being made.
Why don't people just copy Nelson Pass's designs or other great designs of the past and present to get maximum performance? Is there copyright laws in effect for 30 years?Most people just listen to music and watch movies. I EXPERIENCE them.
