Magnifi Max sound bar amber light blinking
the speaker is not responding to anything. i have pulled the plug, pressed the reset button, the subwoofer sync button, the mute button, the input button. nothing is working. how can i get it to start working again?
  • [Deleted User]
    [Deleted User] Posts: 7,598
    Hello,
    The best thing to do is call Polk at 1-800-377-7655 select option 1 and have the serial number handy when you call.
  • geedee
    geedee Posts: 4
    ok thanks. called them. they said sound bar has gone into PROTECT MODE for some reason.
    It is very unsettling that month old $500 sound bar has become useless without extensive use.
  • mlistens03
    mlistens03 Posts: 2,767
    geedee wrote: »
    Something probably just failed. Tends to be the norm with electronics, unfortunately.
    Did you push it hard before it started? That could have caused a short in the subwoofer driver and caused the amp to go into protect.
