Hum noise
Hi Ya All,
Happy Friday and very happy (I hope) weekend. Forgive me if this has topic been here for a few times. I tried to find answer by going through the previous posts, but could not get clear understanding. So thought to post.
I have been noticing an annoying hum noise in my HT system. The processor is Marantz AV7702MKii. All sources are connected to the processor including cable box, roku and blue ray player. The power supply is through Belkin power conditioner to which power plug of two amps are connected as well.
The humming noise was really annoying. So I started to take off the sources one after another in order to understand where it is coming from. Unplugging them did not help. Then I started to disconnect the HDMI cables, one source at a time. And the cable between the cable box and processor did the trick. This HDMI cable is not what the cable company provided, but it is a bluejeans cable. The same type of cable is also connected between roku and the marantz processor, but I do not see any humming issue from roku.
So, what can I do to solve the cable box hum. One option is to disconnect at times when I am not watching the cable. But that is kinda pain in the rear.
Any suggestions??- I was thinking to try another HDMI cable and see what happens.
  • kharp1
    kharp1 Posts: 3,453
    I've seen where the cable box has been the culprit in several hum cases.
  • mpitogo
    mpitogo Posts: 478
    edited June 2018
    Does the Marantz pre have a 3-pin IEC connector with ground? If not it may be a floating ground. Cable companies always (typically) grounds their coax to earth and you likely have a ground loop. You can look it up but basically there is a difference in potential between the two components’ ground. Try connecting the cable box ground if one exists or a chassis screw to the receivers ground if a phono input exists. All of the components should reference the same ground. The cable box is carrying earth ground on the shielding bringing it into the box and the box may only have a two pin power connector.
    Does the Belkin power conditioner have a grounding screw? You can reference this for all components with a chassis ground if they don’t use a standard IEC 3-pin C13-C14 to 5-15 power cable.
    • Living Room Music-2.0 Polk Legend L800 | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Belkin Soundform Connect | iPad Air USB to DAC
    • Media Room Ht-7.2.6/13.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x4], height LSiM703 [x6], HSU VTF-15H MK2 Dual | Marantz AV8805A | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Sony UBP-X800 | AppleTV 4K | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.0 Ascend Acoustics Sierra LX, DSW microPRO3000 | Rotel RA-1570 | Marantz HD-CD1
    • Daughter's Bedroom 1-2.0 TBD Martin Logan Forte | Roku TV
    • Guest Room 2-2.0 Klipsch RP-600M | Martin Logan Forte
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Topping DX7s | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
  • kharp1
    kharp1 Posts: 3,453
    Yep2 wrote: »
    Every component has a "potential difference".
    There's a difference between "every component have potential differences" and the ground potential difference causing a hum.
  • Mr. Sharpe
    Mr. Sharpe Posts: 1,354
    Hey buddy, when I unplug my cable line from the box my Him/buzz will stop, if the wire touches the box it will start. I second the ground loop. Same thing happened at my parents old house and it made me so mad bc I couldn’t listen to music without hearing it.
    Home theater:
    43” Westinghouse Displayer
    Marantz UD-7007 Player
    Emotiva MC-700 Processor
    Adcom GFA-5006 Amplifier
    Parasound Zamp Amplifier
    Ethereal ESO-1 Power Conditioner
    Klipsch RC-10 Center
    Klipsch R34c Fronts
    Klipsch RB-41 Surrounds
    Polk audio PSW-505
    Stereo:
    Polk audio RTA-12c’s fully upgraded crossovers
    DIY 12tc braided speaker cables
    Denon DVD-5910ci Spinner
    Parasound P6 Preamplifer
    Parasound HCA -1500a Amplifier
  • jumpindick
    jumpindick Posts: 428
    I agree that it can be so frustrating. Those cable boxes are cheap... I am in the process of getting another one (not sure if that will help) and see if anything changes. If not, I will have to look for another way to stop the humming noise and still use the cable box.
  • niente
    niente Posts: 68
    I also had same issue with cable box.
    IMHO Its due to difference in grounds. Amp etc grounded through house wiring.....cable grounded outside house.
    Is your cable box 3 pronged plugged into same circuit?
    Add RF isolator...
    Save$ and get rid of cable! No hum either!
    Good luck
    Onkyo TX-SR804 receiver
    Parasound 5250
    LSI 15's
    LSI C
    LSI FX's
    PSW1000 Sub
    OPPO 93
    Sony CDP-C315 CD
    Monster AC line cond
    Audioquest, Blue Jeans & Monster wires/connects
    40" Sony Bravia XBR6
  • Airplay355
    Airplay355 Posts: 4,298
    Who is your cable provider?
  • jumpindick
    Spectrum, in Florida. I have requested another cable box. I have not had chance to play with the new one yet, as life has been hectic lately. I am also getting a new "better" HDMI cable as well. Although the current HDMI cables are from the same manufacturers (bluejeanscable). The one connected with ROKU is perfect, and no Hum. The problem is with the cable box.
    Let's see how the another cable box will do... I will post my observations.
    msg Posts: 9,466
    As noted above, it's most likely not the box, but a difference in multiple grounds in your system.
  • Airplay355
    Their boxes are horrible. I ditched the box completely and just use some kind of DVR card as my "equipment" since you've got to rent something from them. I use a Roku and the Spectrum app. No hums, much faster and better interface, and no renting tons of boxes.
  • jumpindick
    You know that is a good idea. I did not thought about it. Does it allow to watch live tv or is it strickly on the go, pre-recorded shows? I am gonna dig into this.
  • machone
    machone Posts: 1,478
    Hulu live tv is 40 month and includes all the espn channels. I have been trying it this week and plan to cut the cable soon.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
