Advice, Please? I got an unexpected call yesterday...
stretchl
stretchl Posts: 1,334
edited June 2018 in Electronics
...and it turns out I have some extra liquidity which will enable me to upgrade my system.
I run lossless WAV files into a Squeezebox Touch and then to a Grant Fidelity Tube DAC-09. I'm primarily amping with a Yaqin MC-10t, but sometimes using an an Adcom GFA-555 II with my old Luxman R-115 amp as a pre. Speakers are LSiM-705's.
If you had $10k to upgrade this system, what would you do? I'm partial to tubes but would possibly... possibly... consider solid state. The McIntosh name and legacy has my attention, as it's never been in my price range before. But I'm very open to others.
Thanks very much -
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
Best Answers
    Clipdat Posts: 13,094
    Answer ✓
    Maybe a MastersounD integrated? @DSkip
  • MrBuhl
    MrBuhl Posts: 2,419
    Answer ✓
    I'd take aim at that Adcom/Luxman combo if it were me. Nothing against them, but for that kind of scrap - you could get into something like a Pass pre and amp that would likely be an eye opener.
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • Emlyn
    Emlyn Posts: 4,702
    Answer ✓
    I'd start with the source. Although I use Squeezebox Touch players as WiFi streaming sources as a convenience there are more highly resolving devices available now.
    nooshinjohn Posts: 25,910
    Answer ✓
  • tratliff
    tratliff Posts: 1,776
    edited June 2018 Answer ✓
    stretchl wrote: »
    Thanks very much -
    You can't go wrong with McIntosh and Legacy. But I'm partial to both brands.
    Answer ✓
    If the SB touch is just simply passing the .wav through and outputting it via it's digital output, is it really imparting anything audible on the source material?
    Emlyn wrote: »
  • Emlyn
    Emlyn Posts: 4,702
    Answer ✓
    Clipdat wrote: »
    Yes, the power supply is one of its weak points that some workarounds have been developed for. FLAC is probably the best format to use with the Squeezebox over WiFi because of bandwidth and file sizes. The sound is really good, but there are better sources. The Squeezebox also can struggle with high resolution audio formats and can't handle DSD at all.
    tonyb Posts: 33,072
    Answer ✓
    tratliff wrote: »
    stretchl wrote: »
    Thanks very much -
    I might agree also, you can look for a used Butler amp too which I found matched up well. Also a better pre amp would help some too. Joule, Cary, Belles, Vac, VTL. Don't blow the wad on just speakers though, other things will take up some coin too. Cables ?? Pre ? Dac ? Amp ? If Legacys are up your alley, shoot for a used pair of Focus 20/20's. At around 2k for a used set, you get an awful lot of speaker for that coin and leaves lots of room to upgrade the rest of the system.
    This is really a loaded question with infinite responses.
  • kharp1
    kharp1 Posts: 3,453
    Answer ✓
    I agree with Tony, take your time, do some research and look for some good deals in the preowned market. I good pre is just as important as a good pair of speakers...and amp.
Answers
  • stretchl
    This is all such great feedback. And I'm sure there will be more from others. What a great community of folks. :)
    - Isaac Asimov
    Hi-Fi
    Visuals
    So.... what are you gonna do?
    After careful consideration on all of our suggestions, he decided on a stereo dimensional array of Hello Kitty boomboxes.
  • stretchl
    Starting out with something I've wanted for a while and that can replace my Squeezebox touch and my crappy DVD player. (We don't watch many movies...)
    So...
    A ModWright Oppo BDP-105 with a matched pair of Sophia Electric Grade A 6SN7 matched pair (for player) and an Emission Labs 5U4G Mesh tube (for power supply) are en route to the house.
    Beyond that... we'll see... :smile:
    http://www.modwright.com/modifications/oppo-bdp83-and-bdp83se-mod.php
    - Isaac Asimov
    Hi-Fi
    Visuals
  • rooftop59
    rooftop59 Posts: 8,121
    that modded oppo looks sweet!
    Game Room 5.1.4:
    Bedroom 2.1
  • stretchl
    That looks like a hell of a deal. But I’m thinkjng now that I may max my spending out at ~$5k or so. And I for sure don’t have an amp that would to a unit like this justice.
    I got my 705’s during the two for one sale you may remember from a while back. Wondering if I should sell them at a profit and upgrade to the 707’s. Haven’t really researched them in comparison since the sale, but from what I recall there was something that steered me away from the 707’s.
    Lots of thinking out loud here, obviously...
    - Isaac Asimov
    Hi-Fi
    Visuals
    IMO, stick with your current speakers as they are fantastic.
  • stretchl
    I seem to be wanting a bit more bass at times. Could obviously be due to other links in the chain...
    - Isaac Asimov
    Hi-Fi
    Visuals
    What genre of music are you listening to where you notice that?
    stretchl wrote: »
  • stretchl
    Eh. I’d be hard pressed to say when I notice t. Larry listening to a lot of Willie, some Queen, The Who, R.E.M., Zep, Bach piano fugues... Hall & Oates playing now. So no rhyme or reason. I’ll have to pay more attention to when I need more cowbell... we, bass. :smile:
    - Isaac Asimov
    Hi-Fi
    Visuals
    With that type of music/genres, I don't think moving to the 707 would net you any additional bass response.
    stretchl wrote: »
