Advice, Please? I got an unexpected call yesterday...
stretchl
...and it turns out I have some extra liquidity which will enable me to upgrade my system.
I run lossless WAV files into a Squeezebox Touch and then to a Grant Fidelity Tube DAC-09. I'm primarily amping with a Yaqin MC-10t, but sometimes using an an Adcom GFA-555 II with my old Luxman R-115 amp as a pre. Speakers are LSiM-705's.
If you had $10k to upgrade this system, what would you do? I'm partial to tubes but would possibly... possibly... consider solid state. The McIntosh name and legacy has my attention, as it's never been in my price range before. But I'm very open to others.
Thanks very much -
Thanks very much -
“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
- Isaac Asimov
Hi-Fi
Visuals
Best Answers
Maybe a MastersounD integrated? @DSkip
I'd take aim at that Adcom/Luxman combo if it were me. Nothing against them, but for that kind of scrap - you could get into something like a Pass pre and amp that would likely be an eye opener.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
I'd start with the source. Although I use Squeezebox Touch players as WiFi streaming sources as a convenience there are more highly resolving devices available now.
https://www.audiogon.com/listings/lis9000e-pass-labs-xp-10-linestage-warehouse-find-solid-state
https://www.ebay.com/itm/PASS-LABS-XA30-5-Stereo-Power-Amplifier-Silver-Class-A-Stereophile/282987983249?epid=2282466573&hash=item41e365f191:g:GLYAAOSwjB9a0gyR
https://www.audiogon.com/listings/lis8j474-ps-audio-perfectwave-dac-da-converters
Here you go... you are all set.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Thanks very much -
You can't go wrong with McIntosh and Legacy. But I'm partial to both brands.
2 Channel Rosso Fiorentino Volterra II, 2 REL T9x, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Signature 21 w/Hana Umami Red, ModWright PH-150, SonoruS ATR10, AudioQuest Niagara 7000 w/Dragon power cable, WAY power cables for all other sources, WAY Silver 3 Ana+ speaker cables, WAY interconnect cables -
If the SB touch is just simply passing the .wav through and outputting it via it's digital output, is it really imparting anything audible on the source material?I'd start with the source. Although I use Squeezebox Touch players as WiFi streaming sources as a convenience there are more highly resolving devices available now.
Yes, the power supply is one of its weak points that some workarounds have been developed for. FLAC is probably the best format to use with the Squeezebox over WiFi because of bandwidth and file sizes. The sound is really good, but there are better sources. The Squeezebox also can struggle with high resolution audio formats and can't handle DSD at all.
Thanks very much -
I might agree also, you can look for a used Butler amp too which I found matched up well. Also a better pre amp would help some too. Joule, Cary, Belles, Vac, VTL. Don't blow the wad on just speakers though, other things will take up some coin too. Cables ?? Pre ? Dac ? Amp ? If Legacys are up your alley, shoot for a used pair of Focus 20/20's. At around 2k for a used set, you get an awful lot of speaker for that coin and leaves lots of room to upgrade the rest of the system.
This is really a loaded question with infinite responses.HT SYSTEM-
lsi 9's -
I agree with Tony, take your time, do some research and look for some good deals in the preowned market. I good pre is just as important as a good pair of speakers...and amp.
Answers
This is all such great feedback. And I'm sure there will be more from others. What a great community of folks.
- Isaac Asimov
Hi-Fi
Visuals
http://Vimeo.com/channels/stretchphoto -
So.... what are you gonna do?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
After careful consideration on all of our suggestions, he decided on a stereo dimensional array of Hello Kitty boomboxes.nooshinjohn wrote: »So.... what are you gonna do?
Starting out with something I've wanted for a while and that can replace my Squeezebox touch and my crappy DVD player. (We don't watch many movies...)
So...
A ModWright Oppo BDP-105 with a matched pair of Sophia Electric Grade A 6SN7 matched pair (for player) and an Emission Labs 5U4G Mesh tube (for power supply) are en route to the house.
Beyond that... we'll see...
http://www.modwright.com/modifications/oppo-bdp83-and-bdp83se-mod.php
- Isaac Asimov
Hi-Fi
Visuals
that modded oppo looks sweet!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Nice score Stretchl… Look at this next.
https://www.audiogon.com/listings/lis8jih9-pass-labs-x-0-2-solid-state
That looks like a hell of a deal. But I’m thinkjng now that I may max my spending out at ~$5k or so. And I for sure don’t have an amp that would to a unit like this justice.
I got my 705’s during the two for one sale you may remember from a while back. Wondering if I should sell them at a profit and upgrade to the 707’s. Haven’t really researched them in comparison since the sale, but from what I recall there was something that steered me away from the 707’s.
Lots of thinking out loud here, obviously...“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
IMO, stick with your current speakers as they are fantastic.
I seem to be wanting a bit more bass at times. Could obviously be due to other links in the chain...“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
What genre of music are you listening to where you notice that?I seem to be wanting a bit more bass at times. Could obviously be due to other links in the chain...
Eh. I’d be hard pressed to say when I notice t. Larry listening to a lot of Willie, some Queen, The Who, R.E.M., Zep, Bach piano fugues... Hall & Oates playing now. So no rhyme or reason. I’ll have to pay more attention to when I need more cowbell... we, bass.
- Isaac Asimov
Hi-Fi
Visuals
With that type of music/genres, I don't think moving to the 707 would net you any additional bass response.Eh. I’d be hard pressed to say when I notice t. Larry listening to a lot of Willie, some Queen, The Who, R.E.M., Zep, Bach piano fugues... Hall & Oates playing now. So no rhyme or reason. I’ll have to pay more attention to when I need more cowbell... we, bass.
