Cleaning Vinyl Records?
I guess I've been lucky, I just use a CF brush like that, and/or a quick wipe with a microfiber towel.
Sometimes a few blasts from a compressed air can if there's a lot of dust on a record.
Yes sir! You’re lucky!
Video: LG OLED77B4PUA * Sony BDP-S470 * Roku Ultra * APC H10 -
Or I'm just stupid, and I've never actually played back a "clean" record, since supposedly even brand new records straight out of the shrink wrap are not "clean".Yes sir! You’re lucky!
Or I'm just stupid, and I've never actually played back a "clean" record, since supposedly even brand new records straight out of the shrink wrap are not "clean”
I just cleaned some brand new records and I got a bunch of junk off the Doors album but hardly anything came off the Pink Floyd or Halsey albums. You never know and I think it’s better to be safe than sorry.
Even after cleaning the new Halsey album, the last track on side A is all static. Every other track is dead quiet. The last track on side B has some static but nowhere near as bad as side A. Weird
Could be a manufacturing issue with the way it was pressed? Might try returning it for another copy if you purchased it from Amazon or somewhere with a nice return policy.Even after cleaning the new Halsey album, the last track on side A is all static. Every other track is dead quiet. The last track on side B has some static but nowhere near as bad as side A. Weird
I got it before I went into the hospital so I think the 30 days are up.HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
Time to write a "sob story" email to the record label and see if they'll hook you up with a new copy.
I've had mixed experiences with this route. Sometimes labels reply and are helpful, other times they ignore.I got it before I went into the hospital so I think the 30 days are up.
Its amazing how much gunk comes off some albums. As stated some more than others. I wash them all, even new ones. More times than not there is a noticeable difference in sound quality when washing your previous familiar albums. Its rare that i will spin a record before washing it at least once myself.Denon AVR X4200W
Parasound A23 amplifier
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Denon DP 3000 turntable
Saec 308sx tonearm w/
Dynavector 10x5 cart
Vincent PHO 701 Phono Preamp
MIT Avt3 Speaker c's
Audio Quest Big Sur ic's
Polk SDA 1C's modded
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Polk DSW PRO 440wi sub
Infinity bu2 sub
"The early Klingon gets the Gagh" -
You guys are welcome anytime to come over and wash my 900+ records.
Got Beer?/\/\/\Denon AVR X4200W
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Infinity bu2 sub
Nope. Not for 11 months now. My fridge is stocked with La Croix sparkling water instead.
https://www.youtube.com/watch?v=LB_YWGuYGn4Got Beer?/\/\/\
Ha...water juice. Funny stuff.
Denon AVR X4200W
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Infinity bu2 sub
It’s a labor of love and I don’t love doing it, even to my own records. You couldn’t pay me enough to do this for someone else. It’s a PITA IMHO.You guys are welcome anytime to come over and wash my 900+ records.
Too true, never thought I would get through my measly 250+. But it's really a once and done for me I hope. Did the US cleaning routine including pre and post cleaning rinse. Very happy with the results.Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
No wonder you don't have any storage space left.
I've just completed a DIY Ultrasonic record cleaner project. I'm using slotted rubber rollers instead of a rod-through system. I only have a few hundred albums so I thought I'd build my own for something to do.
The 6L tank was purchased online and the same goes for the (1) r.p.m. 110V electric motors.
I'm using an Edwards Audio TT3 table with a Nogaoka MP-500 cartridge so I wanted the records to be as clean as I could get them and I thought I'd try Ultrasonic cleaning as a non-contact cleaning method.
I fill the tank with Reverse Osmosis water, a few drops of "Jet-Dry" Rinse-Agent as a surfactant and a few caps of Isopropyl. I set the timer for 15 minutes (which is what it takes to spin the records once).
Considering the records are 1/3 submerged to start with, (1) revolution seems more than enough to do a thorough job.
I had some initial concerns as the very first (and brand-new album) that I pulled from the tank and air-dryed, was FULL of ticks and pops.
This turned out to be simple static buildup so I changed up the way I was cleaning to add a mist of R.O. water and a rub-dry with another used (but clean) microfiber towel (as new ones shed for a while), immediately after they leave the tank.
The only issue so far is after (4) cleaning sessions, (12) albums, the water gets up to 40C without using the tank's heater so I either change the solution in the tank or let it cool down.
I have some albums that are 60+ years old and I have no idea where they came from but the filthiest albums come out shiny clean and are super-quiet.
I'm a fan of this cleaning method. -
My regimen that works well:
- LAST power cleaner (for new records)
- AIVS enzyme-based cleaners
- Alcohol-based cleaner
All of this on an ancient VPI 16.5 vacuum cleaner.
I use Blutack to clean the stylus, and LAST stylast to preserve it.
I like LAST products, and when my enzyme cleaners are gone, I'll probably just move to his record cleaning solution.
And finally, I use the AudioQuest record brush for small dust and anti-static.
Do you have any photos of this slotted rubber rollers bit?Tramsparent_ wrote: »I've just completed a DIY Ultrasonic record cleaner project. I'm using slotted rubber rollers instead of a rod-through system. I only have a few hundred albums so I thought I'd build my own for something to do.
I disabled signatures. -
Not much to look at but it works well and is only for my use.
An electric motor at one end of each aluminum shaft.
The rollers are where your static is coming from.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Once I remove the albums from the tank, spray them with a mist of RO water then rub them with a damp microfiber towel, the static is gone anyway.
But thanks for the tip about the rollers, it's unlikely I would have considered that.
