Adding PSW505 to A7's and A6
Moving into a new house and setting up audio in the living room with a Denon 730H Receiver, 2 floor standing A7's A6 Center, and have a PSW505 arriving today for my sub. Any suggestions at setting or speaker placement to best maximize sound in a 12x22 ft room with 12 foot ceilings? Thanks for the help!
  • FestYboy
    FestYboy Posts: 3,861
    Get a second sub. That's a lot of room to fill.
    Then do the subwoofer crawl for placement.
  • mrloren
    mrloren Posts: 2,471
    edited May 2018
    eeks! Send the 505 back and get an HSU or SVS.
    The 505 is a good sub for the money but a HSU VTF2 will in most cases out perform two.
  • FestYboy
    Agree, I should have added that tidbit myself.
  • jwb0007
    jwb0007 Posts: 62
    jaugustine, had the RTi12s and CSi A6 myself, until fairly recently (moved, different layout now).
    Anyway, my questions:
    1. Do you listen at "loud" levels often?
    2. Do you often listen to music with notes/instruments going below about 25Hz--at volume?
    I also had a large cubic foot area, and I had one Outlaw sub. I now have 2 of the PSW505s, and love their sound. Plenty of volume, rumble, and subtlety (to me). Admission: don't often listen to a 32' organ pipe at about 20 or 19Hz.
    Of course, it could be that I simply have learned to want what I have, rather than have what I want (which can change so frequently). :)
    Jim
    St. Louis, MO
    AVRs: Yamaha RX-A2030, Onkyo TX-NR646
    Speakers: BIC FH6-LCR x 3, BIC FH-65B x 2, Polk RTi6 x 2, Infinity Primus P362, Klipsch KSF-C5
    Subs: Polk PSW505 x 2, Polk PSW10, Klipsch Synergy Sub-10
  • Jaugustine
    Jaugustine Posts: 3
    Mostly the audio setup is used for home theater for the family. I set up the new sub last night and re calibrated the speakers and feel as if I need to do a bit more tweaking. I put on "The Last Jedi" and tested out some battle scenes and the sub did a commendable job, however I did find aiming it at the back wall helped. No complaints about the sound quality, just trying to manage expectations with the room, Spousal Acceptance Factor, and budget I have. Any opinions on setting the speakers to "Large" vs small and adjusting the crossover on these speakers based on the size of the room?
    Thank you for the input...
    James
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    For HT the 505 is acceptable IMO. I use one also, but like so many others the amp failed and needed to be replaced after a couple years or so and perhaps sooner if used frequently.
  • FestYboy
    I'm running 3 (505s) in HT mode and have approx the same volume to fill. One would never cut it for me.
  • jwb0007
    jwb0007 Posts: 62
    jaugustine, make sure to set your speakers to "small". Has nothing at all to do with the physical size of the cabinets/woofers, but rather the fact that you have one or more subs to do the low frequency lifting, and enable your L/C/R & surround speakers to handle the frequencies above where you set the crossover. FYI, I and others, set the Polk RTi12s to "small". Worked great!
    Jim
    St. Louis, MO
  • Jaugustine
    Jaugustine Posts: 3
    Thank you for the tips. Have the speakers set to "small" and after listening and watching Saving Private Ryan this weekend I was really impressed with the overall sound. I dont see an Atmos setup being approved by my wife in the near future, but there is always hope!!! Thanks again for the help!
