AVR -> Preamp -> Amp ?
alucididea
in Electronics
So, I’m not very happy with using my Yamaha RX-A3070 as my preamp/DAC and I’m considering getting a DAC for all my 2 channel content, including MQA.
My question is whether putting a proper DAC in the signal flow is okay for my surround sound by way of connecting my AVR’s front speaker outputs to the SE input on the DAC. Is there any reason this wouldn’t work well or I might not like the results?
Because the Yamaha DAC is still in the signal chain doing it that way.
"Unwad those panties and have a good time man. We're all here to help each other, no matter how it might appear." DSkip -
??? Digital goes to the DAC...Analog from DAC goes to input of pre ampMy New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Mikey081057 wrote: »??? Digital goes to the DAC...Analog from DAC goes to input of pre amp
All surround processing goes through the Yamaha. Analog front channel output goes preamp/DAC via a SE input.
All 2 channel content goes only through the preamp/DAC.
The only DACs available with HT bypass (which is what you are talking about) are ones like the Benchmark DAC3(?), Wadia 321, Wyred 4 Sound's DAC 2v2, etc.
It is not a common feature on most DACs. It is a more common feature on better 2 channel pre-amps (and some with built in DACs.
That'll work, did it myself for a long time but the wife got super confused when trying to watch a movie or just play music. Audio nerds like ourselves, no problem, anyone else and they look at it like deer in the headlights.HT SYSTEM-
lsi 9's -
Yes you can do it. I have your setup in my family room. The family also does not get confused as the AVR trigger 12v overrides the 2ch Integrated Amp into HT bypass for SE L/R in surround or Atmos. With the AVR off the L/R can be controlled independently using the integrated’s inputs including onboard DAC.
- Living Room Music-2.0 Polk Legend L800 | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Belkin Soundform Connect | iPad Air USB to DAC
- Media Room Ht-7.2.6/13.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x4], height LSiM703 [x6], HSU VTF-15H MK2 Dual | Marantz AV8805A | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Sony UBP-X800 | AppleTV 4K | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
- Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
- Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
- Office-2.0 Ascend Acoustics Sierra LX, DSW microPRO3000 | Rotel RA-1570 | Marantz HD-CD1
- Daughter's Bedroom 1-2.0 TBD Martin Logan Forte | Roku TV
- Guest Room 2-2.0 Klipsch RP-600M | Martin Logan Forte
- Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
- Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Topping DX7s | Sansui FR-1080 | Fire TV
- Maintenance: Pro-Ject VC-S Record Cleaning Machine
alucididea wrote: »
I swear by the harmony remote. I’ve had many generations and the latest iteration with a base two IR emitters and WiFi connection is incredible. It also includes integration with IFTTT so I can trigger room actions ia voice for very little cost vs custom integration with product like crestron or control4 and the like. Eg “ OK google watch TV” triggers watch TV action on the harmony, closes the shades and dims the lights if they are open or on. For the other room actions I use a Wink hub to control the smart home. Again these are things which you can DIY for very little $ vs custom install. The smart shades besides the HT gear would be the a little more money than manual shades.
Control and configure via remote or via iOS app. Wife and kid friendly for one button (or voice command) operation a complex sequence of startup options.
Post edited by mpitogo on- Living Room Music-2.0 Polk Legend L800 | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Belkin Soundform Connect | iPad Air USB to DAC
alucididea wrote: »
Control and configure via remote or via iOS app. Wife and kid friendly for one button (or voice command) operation a complex sequence of startup options. -
Speaking of Harmony remotes....dunno if you saw that their was a security update needed for those with wired/wireless network connection.My New Year's resolution is 3840 × 2160
