Polk 1.2tl-Mcintosh amp hook up question
motorstereo
motorstereo Posts: 2,359
I have a pair of 1.2tl's with the dreadaught and I drive them with a pair of Mcintosh mc1201's monoblocks. I use a pair MIT shotgun bi-wires and I'm super happy with the sound. Problem is I've recently read that I'm able to get 3 db more bass output by using the 8 ohm tap for the lows and 4 ohm tap for the tweets. I decided today would be the day I'd give this a shot. I'm presently using the 4ohm tap fullrange. I checked the 1.2's inputs with a meter and I get 3.9 ohms with the interconnect cable disconnected for the woofers and neither side registers anything on the meter with the tweeters which are rdo1098's. My questions before I go any further will I ruin anything by doing this form of bi-wiring and will I gain that 3db if it's safe to wire the 1.2s like that?
edit; Also is that normal for the 1098's to read zero resistance?
Best Answers
    nooshinjohn Posts: 25,966
    Answer ✓
    You don't need 3db more from the from the Polks when paired to the big Mac's...
  • tratliff
    tratliff Posts: 1,805
    edited May 2018 Answer ✓
    @motorstereo why not give it a try? You won’t know how it performs until you try.
    I have read and responded to the thread on the other sight. I could absolutely tell a difference. At this point I cannot tell if it is for the best but for sure gives options.
  • tratliff
    Answer ✓
    ZLTFUL wrote: »
    Not to mention, 3db is *barely* audible to the human ear.
    Not sure I agree 100%. Depending on room acoustics this could help resolve some deficiencies.
  • motorstereo
    Answer ✓
    tratliff wrote: »
    I have read and responded to the thread on the other sight. I could positively tell a difference. At this point I cannot tell if it is for the best but for sure gives options.
    That's great that you were able to hear a difference. I'm probably going to give it shot on my khorns first where an additional 3db of bass output would be worthwhile. As was mentioned and I agree there's not a need for an additional 3db of bass on the polks but who knows maybe just maybe this method just might sound better. The tweeter circuit not showing anything on the ohm meter had me concerned and I don't want to wreck something for an experiment so I thought I'd ask here first.
Answers
  • motorstereo
    No I do not "need" it but if it's there I don't want to overlook it.
    ZLTFUL wrote: »
    My pre's volume control (Mcintosh c100) has the volume stepped in 1/2 decibel increments. 1/2 decibel is barely audible; 3db is quite audible to me.
  • verb
    verb Posts: 10,176
    Hey Motor - Just found this thread! Are you still running this way? :smile:
  • motorstereo
    verb wrote: »
    I never did give it a try. Maybe someday.
  • tratliff
    Verb. I tried it with my mc601s about a year ago.
    I have bi-amp cables and connected the low set to the 4 ohm taps and the highs to the 8 ohm taps. I could tell the difference. But after listening for about 10 hours decided to go back to the 8 ohm taps for both. It was nice on some tracks but gave a bit of bloat on others.
    Since trying that I have added two subs to the mix. They have given me the lower frequencies I was looking for without pushing my speakers. The ease of the system drastically changed when I added the subs.
    I say give both configurations a try.
  • motorstereo
    I gave it some thought on trying the dual tap method but a couple issues kept me from ever giving it a try. The garden hose thick MH750 MIT shotguns (thanks f1nut) I use are bi-wires and were a very substantial upgrade in the bass over the Canares I was using. I do not have anything comparable to those MIT's in a single wire run so it would not be a fair comparison. FWIW I still use the 4ohm taps on the 1201's.
    Sometimes it's best to leave things alone and I feel this is one of those times.
  • verb
    verb Posts: 10,176
    Interesting comments - thanks! Yeah motor to dual tap I would need another set of MIT shotguns!
    Trat for sure - subs look like the way to go. Lots more options, and flexibility.
    Love this hobby! :smile:
