Parasound HCA 1000 about to blow
kevhed72
I think....the left side runs pretty hot to the touch even when not driving speakers, and it recently started a pretty audible buzz. Anyone want to take a crack at fixing it?
For a price of course. I would also be open to upgrades if that was in your wheelhouse....
I don’t want to try, but it sounds like something serious, I’d pop off the hood just to make sure it’s not something easy like a blown cap or resistor
Good idea....Ill take some pics. Are you skilled in the SS amplifier arts?
It is a bias thing. You tube it
Smarty pantstxcoastal1 wrote: »
Just trying to give a bias perspective on the situation2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Had a similar problem with my para 1500A minus the buzz. An adjustment of the bias pot with a screwdriver & a digital meter solved the heat problem. The bias was considerably off spec. Really was not difficult at all.Denon AVR X4200W
Parasound A23 amplifier
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Denon DP 3000 turntable
Saec 308sx tonearm w/
Dynavector 10x5 cart
Vincent PHO 701 Phono Preamp
MIT Avt3 Speaker c's
Audio Quest Big Sur ic's
Polk SDA 1C's modded
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Polk DSW PRO 440wi sub
Infinity bu2 sub
"The early Klingon gets the Gagh" -
Uh... you could say that... compared to my sister, yes!
Not really I have a fairly basic view of electronics but I am slowly but surely figuring it all out.
There was a chapter on electricity in my science book and I learned literally nothing. I actually got a B on the test because I put too much information in all the options
If it is the bias, the questions becomes, why did the bias drift so far that it had to be dialed back? Those "pots" don't turn themselves.
"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
correct Brock but they do drift without being turned. Is it cap's of something else in the path I do not know. I have had more than one amp that needed recalibrated and I never turned anything. Once recalibrated they played on for many years.
