the making of cerious technology extreme graphene speakers
I own a pair of these speaker cables. take a read on they are made.
file:///C:/Users/mbold/AppData/Local/Packages/Microsoft.MicrosoftEdge_8wekyb3d8bbwe/TempState/Downloads/Making%20of%20a%20GE%20SC.pdf
sorry you have to copy and paste the link.
http://cerioustechnologies.com/
Puritan PSM156
Puritan PSM156
1200.00 for 4' speaker cables...
I read how they're made and they sure take the tweaks to the max, don't they?
Maybe I'll see a pair discounted in a pawn shop someday....not.
they have two lines the matrix is their top.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Ok.
The Extremes are more in my affordable range.
You've still got a NICE set of cables for sure!
I'll bet all of their cables are some of the finest made!
Can you imagine all the cables in one's system being "Cerius Technology cables"?
NICE!
Just nip the plug end and twist the wire to fit the speaker terminals.
Same sound....less $ -
I know what you're saying.
According to stereo reviews testing of 24 ga., lamp cord and Thick Monster cable, ( they reposted the testing from the past in this months issue of Audio Vision mag.) thicker cable DOES make a better sound that can be heard. But they also only tested Monster. I don't think there was any other Co. making quality cable back then.
It was a shocker to see 4 pages or more on speaker wire "blind testing" and also in depth scientific measurements too, from the past.
