the making of cerious technology extreme graphene speakers
marvda1
marvda1 Posts: 4,962
edited May 2018 in Speakers
I own a pair of these speaker cables. take a read on they are made.
file:///C:/Users/mbold/AppData/Local/Packages/Microsoft.MicrosoftEdge_8wekyb3d8bbwe/TempState/Downloads/Making%20of%20a%20GE%20SC.pdf
sorry you have to copy and paste the link.
http://cerioustechnologies.com/
Puritan PSM156
    Tony M Posts: 11,682
    1200.00 for 4' speaker cables... :o
    I read how they're made and they sure take the tweaks to the max, don't they? B)
    Maybe I'll see a pair discounted in a pawn shop someday....not. :( :'(
  • marvda1
    they have two lines the matrix is their top.
    Puritan PSM156
    edited May 2018
    Ok.
    The Extremes are more in my affordable range.
    You've still got a NICE set of cables for sure! B)
    I'll bet all of their cables are some of the finest made! ;)
    Can you imagine all the cables in one's system being "Cerius Technology cables"?
    NICE!
  • lightman1
    lightman1 Posts: 10,797
    edited May 2018
    Just nip the plug end and twist the wire to fit the speaker terminals.
    Same sound....less $
    I know what you're saying. :);)
    According to stereo reviews testing of 24 ga., lamp cord and Thick Monster cable, ( they reposted the testing from the past in this months issue of Audio Vision mag.) thicker cable DOES make a better sound that can be heard. But they also only tested Monster. I don't think there was any other Co. making quality cable back then.
    It was a shocker to see 4 pages or more on speaker wire "blind testing" and also in depth scientific measurements too, from the past. :)
