Bottlehead SEX - a saga
verb
Well I must admit and credit professor @mhardy6647 for piquing my interest in flea power SET amps! Another enabler amongst us!
About a month ago I decided to get my toes wet. Bought an assembled SEX2.0 amp on ebay. Yes I know!
Got a smokin deal. About 2 hundie shipped. When it arrived, hooked it up, and nothing! Powers on, nothing except a loud screech from the left channel. I quickly shut the thing off, and began communication with the seller.
In the end I got a 75% refund, and kept the amp. What to do? Reached out to the Bottlehead forum, and discovered that Bottlehead does not provide any service for out of production items! A recent change to their policy, as I discovered.
Not to give up, @mhardy6647 and I began PM'ing back and forth, asking questions, and in the end, offered to take a look and repair it for me, if at all possible. Just wanted to say thanks Mark for your generous offer and continued tutelage all things flea power!
Finally, I was referred to a gentleman on the Bottlehead forum, Paul Birkeland, who was recommended by Bottlehead.
It is now in the process of getting repaired, and, ahem, upgraded output transformers, et. al., you know the drill!
More to come!
More to come!
Makes me want to get started on my Zenith tube console... Can't beat free!
Practically speaking, yeah! Can't wait to get that little guy home and play with it. Next piece eventually will be some high efficiency speakers. Rabbit hole, ya know!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Horns will be your new friends.
You should be able to afford these no problem with your fancy engineer salary:
https://www.crutchfield.com/p_714LASCACH/Klipsch-La-Scala-II-Heritage-Cherry.html
"Not I!”, said the fly. -
Horn loaded woofer goodness! -
2 hundie.....nice!
I've built two of their kits. They were fun projects. Next time, start from scratch
Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
2 hundie.....nice!
Yep. Actually with the 75% off, it was 50 bucks!
Friends don't let friends buy Klipsch
I say this a a feller who lived with a pair of Cornwalls for a decade.
Hmmm; I'll be interested in seeing how this turns out. Mainly because I also have an interest in possibly trying out an set amp on my khorns. Just this morning I started reading an old article in a Stereophile mag about adding a 3.3ohm resistor to a ss amp that supposedly closely mimics the sound of an set amp on a pair of Wilsons. I may have to give that a shot once I finish reading that article. Set midrange sound with none of the associated tube amp hassles.....doubtful but possible?
Well, here's the thing -- sure you can do that. All you'll do is artificially decrease the amplifier's damping factor (which, it could be argued, has already had its damping factor artificially increased via negative feedback).
It will certainly have audible consequences.
Here's the thing with high output impedance amplifiers (as are most SETs -- at least
those sans any added NFB): They will "feel" their load (i.e., the loudspeakers) much more than a low output impedance (high DF) amplifier... and
that means that the concept of amp/speaker synergy is really, really important for a low DF amplifier. Trying to emulate a SET's performance into a load that was designed to accommodate a very different kind of amplifier behavior is, to my way of thinking, trying to drive a square peg into a round hole.
Also, and more pragmatically: Don't forget how much power will be wasted forcing the signal through that amplifier with an added series resistance. -
A SET amplifier with K-horns should be pretty good. Especially a good one.
A lower-powered SET with mediocre output transformers (e.g., one that I can afford) will give up some slam compared to what you're used to, but the roughness of the stock Klipsch horns will be much mollified by a decent SET amp.
Certainly helped the Cornies a lot. I couldn't stand 'em with an MC-2100 (midrange that could remove paint or drive a Panamanian stongman out of hiding), but they brought tears to my eyes the first time I hooked a Decware "Zen" SE84B to 'em and listened to Sarah McLachlan.
YMMV, of course (which is what makes this hobby fun and interesting).
@verb if you want to stay away from Klipsch horns. Zu Audio has pretty efficient speaksers. The once a year omen dirty weekend at 12ohm 97db something to look out for. Another is Teton Design Lore 98db. Both are around that the same price point and made in the US.
- Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
- Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
- Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
- Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
- Office-2.1 B&W Formation Duo and Bass
- Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
- Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
- Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
- Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
- Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
- Maintenance: Pro-Ject VC-S Record Cleaning Machine
Oh, yeah -- Zu.
Them, too.
Zu...never heard of them.Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!!
Thanks for the explanation mhardy and yes that makes sense. I do believe I'll skip reading that particular article and go for the real thing when the time arises.
Haha; I agree with you on the MC2100. Try as I might I couldn't get my 2100's to sound good on my k's either strapped or single. Strapping (bridged) actually sounded better which surprised me but not good enough to hold on to them. I swear there's an unpleasant frequency response hump built right into them. -
autoformers or not, the MC2100 (and its little sibling, the MC250, and its fraternal twin, the MC2105) just. plain. don't. sound. great.
At least to me.
... and I've heard a few of each, on some very different kinds of loudspeakers.
So Paul found several issues with my SEX amp. Looks like there was some damage to the power switch and potentiometer (shipping damage?) of which he replaced.
I took the liberty of upgrading the output transformers. Below is an excerpt from the Bottlehead website:
And, there is an additional upgrade. Called the C4S
The amp was completed today and shipped! The saga continues!
Good upgrades!
I added the C4S boards (constant current source) to the Paramours -- bought better iron for 'em, too, but have yet to install. It's probably been, I dunno, a dozen years ago?
Thank you sir! Nice to get the @mhardy6647 seal of approval! Double thanks for defining what the heck C4S means! Tube noobie, ya know!
It stands for Camille Constant Current [something] Source -- designed by the late John "Smoothplate" Camille for Bottlehead.
From their early days as "Electric Tonalities" (the name they originally traded under, even though the products were called "Bottlehead").
Congrats on getting it up and running. With about only a good 1-1/2 watts per channel, you will need high efficiency speakers. I built one years ago and tried it with Klipsch Khorns, Klipsch Cornwalls, and Omega 7A, all with good results. Fun little amp.
Awesome integrated spikes!Congrats on getting it up and running. With about only a good 1-1/2 watts per channel, you will need high efficiency speakers. I built one years ago and tried it with Klipsch Khorns, Klipsch Cornwalls, and Omega 7A, all with good results. Fun little amp.
That is way cool! Chrome plated too! Whoa!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
At the risk of public ridicule, I noticed these rather affordable bookies by Kplisch:
Professor @mhardy6647 et, al, please opine!
Oops, here is the model number:
Klipsch RP-160M-WL
mhardy6647 wrote: »It stands for Camille Constant Current [something] Source -- designed by the late John "Smoothplate" Camille for Bottlehead.
Found it! Camille Cascode Constant Current source!
