Second foray into non-Polk tower speakers
mpitogo
mpitogo Posts: 516
Second foray into non-Polk tower speakers are about to begin. On the way are Totem Hawks. These Hawks are second hand and likely broken in so should sound fantastic.
Let the experiments begin.
  • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
  • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
  • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
  • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
  • Office-2.1 B&W Formation Duo and Bass
  • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
  • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
  • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
  • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
  • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
  • Maintenance: Pro-Ject VC-S Record Cleaning Machine
  • MrBuhl
    MrBuhl Posts: 2,419
    Can't wait to hear your thoughts!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
    Tony M Posts: 11,617
    I've heard a small Totem bookie set-up with a Adcom GFA555II and they were AMAZING! I should've bought them but I wanted the 555II more. :#
    Enjoy. I'm sure the bass will be pretty good. And if you need more, a sub added will make a FANTASTIC and almost unbeatable sound field. B)
  • mpitogo
    mpitogo Posts: 516
    edited May 2018
    @Clipdat that is the world famous pair destined to show up on my door steps on Monday. And yes literally it should be that pair.
    I'm contemplating testing them with two different Amps: McIntosh MA-5200 and the second is the pre/amp C47/RB-1590 combo.
  • mpitogo
    mpitogo Posts: 516
    edited May 2018
    First impressions after four hours and rotating in four rooms.
    Positives:
    1) I really like the sound, the midrange and especially reproduction of female vocals are spot on and I can agree. References across rooms Taylor Swift and Molly Jewel
    2) The soundstage claims are true, the KEF Q100 while on a different budget they really image well but compared to the Totem, the Hawks disappears throwing out a pretty wide soundstage it doesn’t sound like a box.
    3) bass claims are not exaggerated, in two rooms with first shot at placement based on distance to the rear wall and distance apart the Hawks generated a good amount of deep bass surprising for its size. Both rooms happen to be on the 2nd floor of my house.
    Negatives:
    1) the Hawks really need power with the volume dial cranked up
    2) they don’t crank out lots of volume, (but what they do is very sweet)
    3) while the woofer is extra long throw it looks to work really hard to push a moderate amount sound
    All use Airplay optical into the builtin DAC for all rooms except the Sansui which uses the DAC in an iPhone 5. Music played from Tidal app.
    Room 1. McIntosh MA5200, Polk LSi25 vs Totem
    Polk by a smidge, soundstage was fuller in the upper mids and can reach deeper even with the Polk’s subs are normally cranked way way down, they’re a bit hot.
    Room 2. McIntosh C47/Rotel RB1590 Polk LSiM 707 vs Totem
    Polk by a long shot, the 707s are the best full range speaker pair I own. The room may have been too big for the Hawks.
    Room 3. Rotel RA1570 Martin Logan Motion 40/Dynamo500 vs Totem
    Tie, this was the surprising room, the Hawks where able to keep up not necessarily in volume but quality the sub was off in comparisons and when it is active it’s volume is also turned way down and crossover at 40Hz. I can easily see the Hawks in this room with a 12” stand.
    Room 4. Sansui AU-6900 Kef Q100 vs Totem
    The Hawks, this room was also my favorite and the smallest at 16x15.
    Conclusions: the Hawks are amazing with that sweet midrange. Possible improvements, crossover ar 100Hz and blend in a fast sub to do all the high energy bass work. It’s not really needed in smaller rooms.
    Room 1
    Room 2
    Room 3
    Room 4
  • mpitogo
    mpitogo Posts: 516
    @DSkip I haven’t decided which room to set it up in. So I just tried them all. Also in what way do you mean it can obliterate the Polk? The Polk is by no means perfect but what game? On price to performance?
    These are used and near mint but the tacky substance on the woofer is a bit of a concern. It’s a dust magnet and not sure if it’ll eventually dry. I’m assuming it’s well broken in from the previous owner and is a year old so it should have out gassed manufacturing chemicals.
  • mpitogo
    mpitogo Posts: 516
    I haven’t given up on them... I will pull out the ML Motion 40, try the Hawks in the bedroom (Room 3) for one month and see how it goes. Will report back in June.
  • Conradicles
    Conradicles Posts: 6,342
    Only thing I don't like about the Hawks is that they are so small. For some reason I can't get into small floor standers. Small bookies however, I can.
    Maybe I am used to SDA's haha.
    Bet they sound great! I had the Totem Dreamcatchers and they were a very nice sounding tiny monitor.
  • mpitogo
    mpitogo Posts: 516
    No balls, original owner looking for them. If not I can find balls online.
  • Nightfall
    Nightfall Posts: 10,084
    mpitogo wrote: »
    afterburnt wrote: »
    Village Idiot of Club Polk
  • mpitogo
    mpitogo Posts: 516
    balls found!
  • lightman1
    lightman1 Posts: 10,796
    edited May 2018
    mpitogo wrote: »
    balls found!
    Were they in your wife's purse?
  • Msabot1
    Msabot1 Posts: 2,098
    Hawks are decent speakers...for what they are...but will not stand up against 707's given the same amplification in any room...It's like comparing apples to oranges..
  • mpitogo
    mpitogo Posts: 516
    edited May 2018
    I know I was asking for it with those last two posts...
  • Joey_V
    Joey_V Posts: 8,600
    You have 4 stereo rooms?
  • Msabot1
    DSkip wrote: »
    Msabot1 wrote: »
    Not for full range sound. For everything else the Hawk is a far superior speaker but like I said above, it takes effort to pull that potential out.
    Isn't full range the goal in home audio reproduction??...
  • mpitogo
    mpitogo Posts: 516
    @Joey_V :# yes... might be adding a 5th. The new Totem's just displaced ML's in one room and I also have a pair of ACA mono blocks on order.
    @dskip I'm starting to hear the potential half-inch at a time.
  • marvda1
    marvda1 Posts: 4,943
    Msabot1 wrote: »
    DSkip wrote: »
    Msabot1 wrote: »
    which is the better speaker?
    raidho xt-1 80 Hz – 50 KHz
    or
    Polk 707 20 Hz → 40 Hz
    full range does not make it the better speaker.
    Puritan PSM156
  • mpitogo
    mpitogo Posts: 516
    I finally got my balls in the mail! :D I will raise the speakers with the following decoupling solutions, 2” speaker foam blocks then 2” chopping boards followed by the balls and Hawks’ claws.
  • HzTweaker
    HzTweaker Posts: 959
    This is a great thread! The information is awesome but mostly because it made me LOL at work. :) Can't wait to hear your thoughts now that the balls are in the picture. B)
  • Msabot1
    marvda1 wrote: »
    Msabot1 wrote: »
    DSkip wrote: »
    Msabot1 wrote: »
    or
    Well..I guess you have a point...if you have ears of pure Bolivian tin...LOL!..
    tonyb Posts: 33,072
    Marv was raised in Bolivia, a distant cousin to Butch Cassidy....so I wouldn't piss him off too quickly. ;):):)
  • mpitogo
    mpitogo Posts: 516
    edited May 2018
    Balls installed on top of 2” teak chopping boards and speaker foam blocks. Bass is now boomy. Room boundary gain in effect, same location as the previous setup but raised 4”. It seems tweaks with balls and inches do matter and it’s now floor/ceiling speaker height ratio. Speaker positioning is a 3 dimensional affair with these speakers.
  • mpitogo
    mpitogo Posts: 516
    edited May 2018
    Added slight toe in and tilt back with a disk on the front ball helped a bit. Speakers are 7.5’ apart, 1’ from rear wall to backs of the cabinet, 4.2’ from left wall and 7.5’ from right wall. I may need to pull these further into the room.
  • lightman1
    Too much decoupling. Takes the "life" out of the speaker. Try it with the balls on the floor.
    tonyb Posts: 33,072
    lightman1 wrote: »
    I would agree, might be a tad cold though. :)
    pitdogg2 Posts: 27,045
    edited May 2018
    tonyb wrote: »
    lightman1 wrote: »
    Sick muck B)B)
  • joecoulson
    joecoulson Posts: 4,943
    Balls on floor. Lmao
    I have Totem Rainmakers. While they are designed to have extra bottom end with the cabinet/driver design, they are no where near full range. The Totem towers I listened to with Alan when he had Audio Alternative open in Lilburn GA were very nice sounding, but again not full range. I have Polk LSi-m705’s and the are closer to full range, but not all the way there. I say all of this to say that musically the Totems Kill the polks. If I play pure quartet classical, my Rainmakers will do a better job of imaging and separation than the Polks. But the Polks will impress more people not familiar with many different setups. Because they have more range than the T’s. Don’t get me wrong, I love the LSim’s, and they do a great job and are my mains, but it’s like having a 600hp corvette and a 600hp Ferrari. Both go fast, one does it with super style.
  • joecoulson
    I keep getting mail and flyers for the Hifi Buys but I am scared (for my wallet) to go down there and visit.
    Great guy, didn’t care if you were spending $500 or $50,000, would treat you the same.
