Chromecast Audio + Digital Cable
rooftop59
Chromecast Audio in perfect shape in original box. Comes with USB power cable, and I will throw in a charging block (not included with new purchase) and this cable: https://www.amazon.com/gp/product/B00T8HWV62/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 which allows you to get digital audio out to your DAC. Cheapest, easiest way to stream TiDAL lossless!
$25 PayPal F&F, shipped via USPS priority.
@daboyz has first shot at it!
Bedroom 2.1 Harmon Kardon HK3490; Bluesounds Node N130; Polk RT25i; ACI Titan Subwoofer
I will take it if he passes. Thanks.
Thanks Paul for thinking of me but feel free to move it along.
You’re up Conrad!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
If Conrad passes I'm game ,these hooked up to a Dac makes streaming easy.Home Theater
I'll take it. PM coming soon...
Got it hooked up and all is well. Thanks!!!
I have got 2 of em in the house via optical into a Oppo 105D, and and 1going into my Musical Fidelity Dac, these things are pretty slick for streaming. I'm sure Conrad is enjoying his, a lot of entertainment for little coin.Home Theater
I run one with bubbleUpnp, uncompressed wave from my nas into my receivers dac using an optical cable with fantastic results. This thing streams fantastic. Btw if you have a power conditioner that has a usb power port on the front, use it! It does make a difference.
I used four of them to blanket a client's condo. She chooses the zones on her iPad.
Very slick until the zones disappear. Firmware in the last year has reduced that.
$25 was a good price even without the cable.Expect that there will be bumps in the road. Choose to not let them rattle you.
Boston - CR7, CR6s, CR4s.
Thompson Adventures, Inc.
