Jolida JD 100 Remote?
Roy Munson
Hi Guys, I just unpacked my Jolida JD 100 from moth balls and to my surprise I left the batteries in the remote (which leaked all over) and it appears to be ruined. I tried cleaning it out but it's a no go..it's toast.
Does anyone know where I might be able to find a new one.
TIA
TIA
2 Channel:
Amp/Parasound Halo A23
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
Turntable/AR XB-Shure V15 III
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
:'(2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Yeah, I'm pretty bummed.
Dumb move I know but stuff happens.2 Channel:
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
Turntable/AR XB-Shure V15 III -
Send Walter an email....he own Underwood hifi, and a Jolida dealer
He's great people, if he can help he will
Call Walter Liederman at 770-667-5633 with questions
Email- underwoodwally@aol.com2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Thanks, I'll give him a try.2 Channel:
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
Roy Munson wrote: »Thanks, I'll give him a try.
He may be able to give you an alternative, remote idea that carries the same signals for the jd2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Worse case, get a Harmony.Political Correctness'.........defined
President of Club Polk -
Roy Munson wrote: »Hi Guys, I just unpacked my Jolida JD 100 from moth balls and to my surprise I left the batteries in the remote (which leaked all over) and it appears to be ruined. I tried cleaning it out but it's a no go..it's toast.
Well, it sounds like you pulled a total munson on that remote.
I definitely Munsoned it!
However I did find a solution. I contacted Jolida and they still have remotes for the JD100. Apparently the transport they now make uses the same remote. So I ordered one up. Unfortunately it's expensive at $100.00 plus shipping but I got one anyway. Problem solved.
I won't be leaving the batteries in this one.2 Channel:
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
Roy Munson wrote: »I definitely Munsoned it!
I figured you would just have them build you a new hand with a remote built right into it!
I'm glad you found a solution. Now if there was just a remedy for that nasty cheese grating accident you had as a young man!
That's what I get for trying to hustle those guys back in the day.
At least I still have my ring.2 Channel:
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
Roy, you have a bunch of posts but I don't recognize the name. Are you a returning old timer or am I just getting less observant?
He was in that movie King Pin duuummy2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I would bet you remember his landlord.
https://www.youtube.com/watch?v=W1WXMirw4D8 -
Whats wrong with her teeth?
Returning old timer. lol2 Channel:
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
The things I had to do. lol
2 Channel:
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
