SVS SB-4000 vs. SB-16 Ultra
alucididea
So I’m trying to decide between these two subs without having the opportunity to listen to them since I live in an area without any reasonable audio store. The power on both are great. The size is irrelevant to me. But after examining the SPL chart, it seems the 4000 slightly bests the 16 Ultra. I’m mostly interested in musical quality but also enjoy the low extension for electronica and rap/hip-hop as well as movies.
The app available is also a decent consideration although I realize the YPAO equalization does a reasonable.
LSIM 707s as my mains powered by an NAD M22/Yamaha 3070.
Price isn’t really an issue, I’ll probably end up with 2 of them by the end of the year anyways.
Am I missing anything? Might any of you have any input I could consider?
Thanks in advance!
I’m also open to hearing other suggestions from other companies though I’m really not trying to spend more than $2k each.
Thanks in advance!
The 16?ultra will have more head room than the 4000, or more reserve if it needs it for bass intensive material.
Hsu and Rythmik are also very good subs at reasonable prices. -
The Rythmic F18 looks pretty solid...The 16?ultra will have more head room than the 4000, or more reserve if it needs it for bass intensive material.
I have a Rythmik F12 SE and it's very nice with music and no slouch with HT duty. I can only imagine how much deeper that F18 would go.2 Channel "Polk" Room:
Marantz PM8004 Integrated
Marantz SA8004 SACD Player
WiiM Mini
Polk 7B with RDO198s -
Check Svs's scratch & dent section I picked up a 16 for $1399 delivered a few months back, one small scratch by the amp. The app is very handy for setting the phase at your listening position.HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
What did you end up getting?
I didn’t end up getting one yet. Just for cost effectiveness I’m thinking I might go with the SB-4000. Eventually I want to have duals, so once that happens I’m sure they’ll be plenty.joecoulson wrote: »What did you end up getting?
I’m also going to explore a couple Rythmic models, specifically the F15HP & the F18. They don’t have quite as much power but I’m liking the idea of a rumble filter more and more, esp silly while I have housemates. -
Ok so just thought I would throw this out there, the SB16 continues to amaze me. The depth of this thing is unprecedented but it’s the speed that surprises me. It’s as fast as a 10 but as much depth as an 18. Totally blown away by this thing. Totally worth the $$
Well that’s good to hear because the SB16 is definitey in contention. It stands out for so many reasons; I just wish it had a rumble filter.joecoulson wrote: »Ok so just thought I would throw this out there, the SB16 continues to amaze me. The depth of this thing is unprecedented but it’s the speed that surprises me. It’s as fast as a 10 but as much depth as an 18. Totally blown away by this thing. Totally worth the $$
