Basement Leak at Verb's House!
verb
Well today was a little dramatic. 2 days constant rain, super high water table, and this morning I noticed a little wet spot on the carpeted floor in the basement. Schiesse!
So I started following the wetness along the baseboard. About 3 feet from the doorway in the spare bedroom.
Popped the baseboard off, lower paneling, and ugh, drywall! What a mess! This is what I found:
A little pin hole in the wall, peeing steadily! What?!
Here is a picture of the mess I just created:
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Hard to tell in the above pic, but there is a steady stream flowing into the blue bucket. I put a fan next to the wet area to help drying. A little later, I hooked up a funnel with a hose near the hole to better direct the water into the bucket. Ugh!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Merde! Gardez l'eau!
Eventually I exposed the true size and nature of the hole. 5/8" diameter, used to hold the forms together as the concrete walls are poured. This guy was never fulled sealed, as the concrete at the pin hole easily popped off, exposing the hole.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
That'll buff right out....
Off to the big box store. Got a rubber cork, with tapered diameters, and pounded that sucker in place!
Leak immediately stopped!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
So now I'm thinking about hydraulic pressure, building behind the cork, and eventually blasting that sucker out of the hole! So I nailed a backer board in place to hold the cork in.
You do know that a correct proper repair should be made from...the...sad to say...OUTSIDE!
Yep. This is just temporary.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Hydraulic cement dude come on
Close the door. Turn the basement rig up loud so you can't hear the trickle. Problem solved.
Only one way to fix it properly... Capture and redirect via perfed PVC.
I did find these new patented plugs that are designed to seal the holes. Called TRX Plugs, they act kinda like a boat seal with a threaded fastener in the middle to increase the outside diameter. What's interesting about these is the rubber compound actually expands when exposed to water!
The basement rig is only about 10 feet away! Ugh! Needless to say I'm gonna keep a close eye on it.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
That stinks to find - but at least you found it so you could limit the damage.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
This stuff expands considerably. The Mrs. reminded me of they act kinda like, uh, something else, that is what I may say, uh, gender specific?
Just ordered a pack of 5 from Amazon. These things are not even available locally yet.
In the meantime, after stopping the bleeding, I mean leaking, upstairs in my nearfield setup enjoying some Linkin Park!
Darth Vader himself might've said:Never underestimate the power of the hydrostatic pressure of water.
Ah yes, P(h)=rho*g*h
Just checked the basement again. No leaks! Celebrating.
That sucks. What's the grade like outside the house? Do you have downspouts extended away from the house, gutters clean? First thing I did when I moved into my 50's ranch was build the grade up all around the foundation to run downhill away from the house. I put in pop up drains for the gutters at least 10ft. away from the house. Don't have any trees near the gutters but still clean them out several times a year from flying leaves all around. Haven't had any water issues what so ever since doing so and I have no sump pump.
That’s a clear indication that you might need to do some work on your water management.
As others have mentioned about downspouts and grading.
But you either need your French drain checked, or have one installed.
Hydrostatic pressure on that plug is the least of your concerns. A basement wall heaving or buckling is a MUCH bigger issue.
You need to get the water away from your foundation.
Do you have a sump pump?
concur, and that was my point -- water pouring through a crack or hole is indicative of a pretty serious water reservoir outside the wall -- and water is pretty uncooperative when it comes to being held at bay.Upstatemax wrote: »
...Hydrostatic pressure on that plug is the least of your concerns. A basement wall heaving or buckling is a MUCH bigger issue.
Thanks to all for your comments and suggestions. My plan is to regrade further the area around the suspect wall to ensure the water drains away from the house. I did the same on the other walls last year with good results.
Downspouts are all good, in fact they are all plumbed to an underground system that dumps the water about 100 feet from the house.
The gutters need a bit of work. They are all in good repair, but I noticed that a few of which the grade needs to be adjusted to allow better flow. Especially at the corners, near the suspect area, where some of the water splashes over. That is also on my list this year!
So this issue of the re-bar holes not being sealed and leaking is quite common, after further reading and talking to my colleagues at work. My plan is to use the TRX plug to permanently seal that particular hole. I probably won't re-drywall for some time, at least through spring, to ensure the fix is robust.
Sump pump is good, operating normally too.
Ahh, the joys of home ownership!
Just got home today and all is good. Dry as a bone! Not to mention big points from the Mrs. for solving a problem! You know how that is, fellas!
Forget all that high tech mumbo jumbo.
BTW @la2vegas how did you know I was of Dutch heritage? 1st generation American! Those Dutchies sure know all about water management!
Of my trips to Europe, visited Holland, never saw anything like this before. Makes sense when virtualy the entire country is below sea level!
Cool. We actually stopped for a bit and watched a few of those ships, including huge freighters travel across the overpass! Amazing!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
If I ever went to Verb's house, I would probably take a leak in his basement. Just sayin'.
I'm sure you will!
