Remodeling our basement...
Takes a lot of freaking time!! Especially when you have a job... :/
Seriously I’m on week 10, finished the bathroom a couple weeks ago, pulled up the old carpet, run speaker wire through the walls, cut two holes in the ceiling for Atmos speakers, redoing the cable for the tv (some other douch did such a great job installing) patching holes, pulled all the baseboards, you know all the fun stuff. I am actually enjoying it I just wish it went faster..
My big issue is wondering if I put my newly painted baseboards in before the carpet is installed..
Looking forward to having our HT room back together, Octane Seats are to be delivered next week...
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Larry, Normally the Base Trim is installed before the carpet. Leave about a 1/2" gap between the bottom edge of the trim and the floor.
    You can go back and touch up any imperfections that will come from installing the carpet.
  • kevhed72
    kevhed72 Posts: 5,191
    Here the scoop with the baseboards....you can install it about a quarter to half inch up from the floor prior to carpet going in. The pad will get cut about even with the board, and the carpet gets tucked under the board. Then you can fill in all the little nail holes and paint over it...no risk of dripping paint on new carpet. BUT, the carpet installers will scuff up sections of the board during the installation. Then you have to go back and touch up those sections. Almost a lesser of 2 evils, but I opted to paint it all first so it went quicker....nobody will see a bit of paint on the sub floor. After reading your post again....putting them in after the carpet would be a PITA. Hope this helps
    F1nut Posts: 52,193
    So, that's where you've been.
  • mrbiron
    mrbiron Posts: 5,721
    I hope you're not putting carpet pad in your basement unless you want a moisture sponge under your carpet...
    Install the bb now. They will direct glue to your slab floor. Leave bb 1/4" off floor so you don't wick moisture. Touch-up scuff marks after installer leaves.
    pitdogg2 Posts: 27,640
    If the floor has been sealed that shouldn't be a problem correct?
    mhardy6647 Posts: 35,421
    edited April 2018
    Depends on the basement, I would opine.
    My thoughts, FWIW, (as a biochemist, not a geologist or hydrologist, much less a house buildererator) -- If there isn't an hermetic seal between the foundation walls and the slab, water will find its way in if there is any in the surrounding soil. Water is still ;) noncompressible, so if there's any sort of pressure on it (say a few billion tons of soil), it will become... heh... a force of Nature.
    Of course @mrbiron lives in eastern MA -- and eastern MA, to a good approximation, is a swamp. Virtually all basements in MA (most of New England, in fact) have issues with moisture incursion at some point in the year, even if it is just dampness (humidity).
  • dolbyd
    dolbyd Posts: 430
    Funny here in Utah we put humidifiers on our HVAC units.
    Everyone has a different issue depending on your location.
    Main room- RTiA9 x4, CSiA6, in ceiling Atmos RT-70 x4, SVS PC 4000 x2, Marantz 8805A, OPPO 203, Emotiva DR3 G3, Emotiva XPA-2 G3, Emotiva XPA-5 G3, Emotiva DR2 G3, Sony 85" Bravia 9, Panasonic Plasma VT50, PS Audio Power Port X2, PS Audio AC-5 x8, AQ Rocket 33 Biwire speaker cables, AQ King Cobra XLR IC, Furman PFi20 W/Cullen cable, SoildSteel S4-4 rack, Gik room treatments
    Office- Legend L600, in ceiling Polk RC80i, Marantz 7704, OPPO 203, Pioneer Elite PDF-59 CD, PSA Stellar 300, Sony 55" 800B, Gik room treatment
    Master BR- Signature ES60, Signature S35 Center, Signature S15 Dolby Height, LSI700 in ceiling, SVS-SB4000, Marantz 5012, Emotiva XPA7 G3, OPPO 203, Pioneer DVL-919 Laser Disc, Sony 80J 55" OLED
    Patio- SDI Atrium8 x3, Emotiva A-100 amps x3
    Toolfan66 Posts: 18,310
    I will more than likely put the baseboards in before hand, in my younger years when I did carpet jobs, the baseboards were always in place..
    Yes we are putting padding down, there was never any issues with the padding that was there, no issues taking it up, I don’t see there being a problem, if water gets in you’re kinda fu€ked anyway..
    Yep, it’s crazy not having my systems up and running for this long..
  • stainless0steel2
    Toolfan66 wrote: »
    You rockin' your Hello Kitty boom box in the meantime?
    The Night is Dark and Full of Terrors
    Toolfan66 wrote: »
    Courtney’s Polk Bluetooth speaker!!
