Blackhole 5
From what I understand, the fiberfill or batting is used to help break up standing waves essentially making the cabinet appear larger to the drivers. It is important to place the fiberfill behind the MWs and not let it extend down into the PR area. As far as the upper Tweeter area I don't think it matters as much.Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA2btl highly modded
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
Thought the Blackhole 5 went behind the MW ?Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM
You use both the black hole and polyfil. Install the BH5 on the back wall of the cabinet and then put polyfil back in. -
The blackhole 5 attaches to the back of the cabinet behind the mids and then the batting goes back into its original space from the top of the cabinet to right above the passive radiator. Nothing below the mids.2 Channel
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
North Star Intenso Dac
Auralic Aries Mini Streamer
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
Yes it does! place a strip 4" inches wide and long enough to cover the area directly behind the MWs adhere it to the back of the cabinet, then place the fiberfill back in it's original position not to extend down into the PR area. Use 1 strip behind the Stereo driver's and 1 strip behind the SDA driver'sYamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
Got it. Both affect the MW. @RandyCroissant I've just got the 7's for now, no SDA drivers to contend with yet
Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM -
I used 3" wide strips. Too much kills the sound and the bass.Political Correctness'.........defined
President of Club Polk -
dkfreebird wrote: »The blackhole 5 attaches to the back of the cabinet behind the mids and then the batting goes back into its original space from the top of the cabinet to right above the passive radiator. Nothing below the mids.
Does it have any effect on the high's? Would be pretty hard to limit the fiber batting to just behind the mids I realize, so it must not matter since the tweets don't really make any internal standing waves ? Is this correct?Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM -
I used 3" strips in my 10's and SDA 2b's.. seems to work great! but that is what @westmassguy & others like Jesse taught us to use.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Yes,I even ran some blackhole 5 behind my tweeters on my 1.2’s.2 Channel
Oppo 103
Pangea PC
think I it was like 3x12 I believe ..Like Dennis said it starts at the bottom of the drivers and goes up towards the top of cabinet and the polyfill goes from bottom of drivers up to the top with none down by the PR's.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
My bad!! 3" wide strips will do the trick. However you will have to get used to the new sound, at first listen they will sound very different from what you are used to. Give them some time, well worth your patience.Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
I'll have a 12" x 18" piece of BH, so got plenty, just want to put the proper amount in the proper location.Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM
Just cut two 3”x6” and put them directly behind the mids.2 Channel
Oppo 103
Pangea PC
Simple enoughCarver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM
Ok Ok. I get it. Subject closed...........
For now.
Just wanted to add, in the Monitor 7's the poly fill is pretty much crammed up at the top with just a bit behind the driverPolitical Correctness'.........defined
Ditto for me also, batting behind the tweets and mids...1C'sDenon AVR X4200W
Parasound A23 amplifier
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Denon DP 3000 turntable
Saec 308sx tonearm w/
Dynavector 10x5 cart
Vincent PHO 701 Phono Preamp
MIT Avt3 Speaker c's
Audio Quest Big Sur ic's
Polk SDA 1C's modded
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Polk DSW PRO 440wi sub
Infinity bu2 sub
"The early Klingon gets the Gagh"
