Final dac- Twisted pear audio 9028 with Mercury output
This is it!!! Best digital I've heard. The BAT preamp and power amplifier are making this dac sound so good. TPA Buffalo pro 9028 with the mercury output stage. New control face in cherry. Old carpathian burl case from the Buffalo III. Sonora Utrarender to the usb input to the t0vhelkh5eun.jpg
Amanero usb converter. It will use the one I2S for the Amanero and the spdif iput will have a 4 input 4:1 adapter so I can have 2 optical inputs and 2 coax inputs. These SDA 2.3s have never sounded this good!!!!!
Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
  • bikerboy
    bikerboy Posts: 1,235
    Not a bad pic for a tablet and no flash.
    Bottlehead Eros
    CD: DIY Shigaclone
    SCompRacer Posts: 9,123
    edited April 2018
    Kewl! Congrats! That output stage is amazing.
    My 9028/Mercury is still on a cookie sheet. I had to get another Arduino shield from Dimitris (dimdim) and have yet to assemble and test it. Working too many hours.
    Once I get Arduino control I'll design an enclosure.
  • bikerboy
    I simplified this one. I use the ultrarender 97% of the time. No Otto or teleporters. It's great to play dsf direct no switching needed. I think I'm using the fast apodizing linear or the hybrid fast minimum phase filters. This dac really upped the sq.
    Bottlehead Eros
    CD: DIY Shigaclone
    This is where I hit pause....I believe I had a bad isolation chip as it would connect with 9028 from the dirty side. However, dimdim is using a BIII 9018 board with a 9028 chip on it.
    EndersShadow Posts: 17,722
    Rich if you can’t make it work, no one can!
