Final dac- Twisted pear audio 9028 with Mercury output
bikerboy
This is it!!! Best digital I've heard. The BAT preamp and power amplifier are making this dac sound so good. TPA Buffalo pro 9028 with the mercury output stage. New control face in cherry. Old carpathian burl case from the Buffalo III. Sonora Utrarender to the usb input to the
Amanero usb converter. It will use the one I2S for the Amanero and the spdif iput will have a 4 input 4:1 adapter so I can have 2 optical inputs and 2 coax inputs. These SDA 2.3s have never sounded this good!!!!!
Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Bottlehead Eros
CD: DIY Shigaclone
Not a bad pic for a tablet and no flash.Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Vinyl rips: ESI Juli@24/192->Goldwave->i7 PC server -
Kewl! Congrats! That output stage is amazing.
My 9028/Mercury is still on a cookie sheet. I had to get another Arduino shield from Dimitris (dimdim) and have yet to assemble and test it. Working too many hours.
Once I get Arduino control I'll design an enclosure.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
I simplified this one. I use the ultrarender 97% of the time. No Otto or teleporters. It's great to play dsf direct no switching needed. I think I'm using the fast apodizing linear or the hybrid fast minimum phase filters. This dac really upped the sq.Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
This is where I hit pause....I believe I had a bad isolation chip as it would connect with 9028 from the dirty side. However, dimdim is using a BIII 9018 board with a 9028 chip on it.
Rich if you can’t make it work, no one can!"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
