Entry Price for a Power Cable Upgrade?
  • voltz
    voltz Posts: 5,384
    Hey Danny
    I am bringing some PS Audio AC3 & 5 and 4 different power cables from Voodoo and a Audio-art I got from Marvinand 3 I got from Doug. So if you can wait 4 weeks till LSAF. you can look over what I have and take what you like home with ya B)
    Clipdat Posts: 13,089
    Not that I know of, it appears to just be Shunyata's entry level cable. From what I can tell, it's just a nice 14awg cable meant for anything with an IEC inlet. I believe most generic cords are 18awg so it should be quite a bit beefier.
    From the Shunyata website:
    "Ideally suited for use with Blu-ray players, flat screen televisions, portable devices, power bricks and a host of other components."
    Also, the specs point to it being A-OK for high current draw applications:
    "CURRENT RATINGS
    – Max continuous current: 20 Amps (connector dependent)
    – Max instantaneous current: >200 Amps (800ms)"
    Hermitism wrote: »
    Isn't the Venom 14 meant for source components? I'm not that familiar with their model hierarchy.
  • BlueFox
    BlueFox Posts: 15,251
    Did you read the Shunyata technical article on DTCD at
    http://shunyata.com/technical-articles/
    This is based on the Venom3, which I believe is the one I bought. Hopefully, the new Venoms are better. :)
    Hadn't seen that, but checking it out now! Thanks.
  • Hermitism
    Hermitism Posts: 4,326
    DSkip wrote: »
    I haven't heard the 9SE, but I wasn't a huge fan of the 9 after I heard other cables.
    I've got two of the 9SE, but never heard the 9. Have both the 14 and 14SE, but I've never heard the 14XL. Did you ever use the 14XL before you became an audio snob? :smiley: I'm just messing with you!! I wish I could do a walk-through at your house!
    Clipdat wrote: »
    Okay, I see. My AVR originally came with a cable smaller than the one on my hairdryer.
    BlueFox wrote: »
    Is it the Venom HC that replaced the Venom 3?
    edited April 2018
    Yes, I believe you're right on the money there, it appears to be the successor. The HC must be designed for those 200wpc+ amps.
    My monoblocks are only 50wpc, so I think (hope?) that they will be just fine with the 14awg.
    Hermitism wrote: »
  • BlueFox
    The Venom3 was the only Venom power cable at that time, which was around 2012 for me. You could get it with 20 amp connectors, which I needed for the CA amps, and Pangea didn’t offer that connector. I did have Pangea AC-14 on everything else back then.
    I'm going into these power cable upgrades with a HEALTHY dose of skepticism. I keep thinking to myself "No way a POWER CABLE can make things sound different/better than they already do...".
    We shall soon see!
  • Hermitism
    When I joined here, I couldn't wrap my head around how a power cable could effect the sound. I thought of it as a component is either getting power or not. If it's getting power, than it's functioning as it should. But even listening to music through an AVR, I could hear a difference.
  • BlueFox
    Good for you. I too was a skeptic. After all, 120 volts is 120 volts, right? Wrong!! LOL
    OK now I know that you're full of voodoo crazy talk. LOL!
    Hermitism wrote: »
  • lightman1
    lightman1 Posts: 10,796
    Y'all just won't listen to logic......
    This is a perfect power distribution conditioner.....
    Oh please, I wouldn't even plug my Hitachi Magic Wand into that POS.
    lightman1 wrote: »
  • BlueFox
    Yea. I got your logic right here. LOL
    So, when are you coming to CA? We should be having some other disaster soon that requires help.
  • Hermitism
    Clipdat wrote: »
    Is that anything like a Lovense Lush?
    It's more oldschool than that new fangled tech!
    Hermitism wrote: »
  • dolbyd
    dolbyd Posts: 430
    Clipdat wrote: »
    Add a New AQ Dragon to that and you can rename it the "Bad Boy 5000"
    Main room- RTiA9 x4, CSiA6, in ceiling Atmos RT-70 x4, SVS PC 4000 x2, Marantz 8805A, OPPO 203, Emotiva DR3 G3, Emotiva XPA-2 G3, Emotiva XPA-5 G3, Emotiva X300, Sony 75" 940E, Panasonic Plasma VT50, PS Audio Power Port X2, PS Audio AC-5 x8, AQ Rocket 33 Biwire speaker cables, AQ King Cobra XLR IC, Furman PFi20 W/Cullen cable, SoildSteel S4-4 rack, Gik room treatments
    Office- Legend L600, in ceiling Polk RC80i, Marantz 7704, OPPO 203, Pioneer Elite PDF-59 CD, PSA Stellar 300, Sony 55" 800B, Gik room treatment
    Master BR- Signature ES60, Signature S35 Center, Signature S15 Dolby Height, LSI700 in ceiling, SVS-SB4000, Marantz 5012, Emotiva XPA5 G2, OPPO 203, Pioneer DVL-919 Laser Disc, Sony 55" OLED
    Patio- SDI Atrium8 x3, Emotiva A-100 amps x3
  • lightman1
    BlueFox wrote: »
    A summer get away is in the works.
  • BlueFox
    Oh no. Earthquake coming. Time to stock up on beer survival gear. Just to be safe, some smokable medicine might be needed.
    mhardy6647 Posts: 34,955
    lightman1 wrote: »
    shhh! Now the prices are gonna skyrocket.
    as seen on Another Forum -- apparently disagreements over the raw materials used in cables dates back farther than one might have thought:
    Just think -- were there no Internet, I'd never have known this.
  • motorstereo
    motorstereo Posts: 2,325
    DSkip wrote: »
    I haven't. There is a difference in sound, that much I know. I haven't heard the 9SE, but I wasn't a huge fan of the 9 after I heard other cables. It's a good starting point in the PC world. My biggest issue is the SQ isn't worth the hassle of hooking them up.
    I have had both the 14 and 14SE and I know there were big improvements between those two, so maybe the 9 and 9SE would have a similar jump that would make it worthwhile.
    I'm wondering what component you had those 9's hooked to that they didn't sound good?? I've just dipped my toe in the entry power cable pool and this inquiring mind is very curious :)
  • mpitogo
    mpitogo Posts: 512
    My next upgrade
    • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
    • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.1 B&W Formation Duo and Bass
    • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
    • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
    • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
  • motorstereo
    DSkip wrote: »
    DSkip wrote: »
    I didn't say they sounded bad, just that they didn't sound good enough to warrant the struggle. It was a definite upgrade over stock, but once I heard other cables around the same price (with similar or better gains) and had no difficulty with installation, I quickly had no desire to ever use the 9 again.
    Believe it or not, they will impart their own signature onto the sound. Pangea will have a slightly rolled off top end that integrates well into most systems. I don't like their AC-9 but loved the AC-14SE. Wireworld is neutral in presentation and won't shift the tonal balance of your system much, if at all.
    I cut and pasted your reply from the other cable thread. I asked the same question of what component you had the 9's hooked up to in the other thread because of the rolled off top end you claimed
    I can certainly understand and I agree with you on not recommending them because they're a major pita to work with. I think the only way they could be used with a lighter weight component is if it had an anvil sitting on top of it. It would also be damn near impossible to try to snake a 9 into a rack. I would have to say a lower radiator hose on a Mack truck has more flexibility :)
  • BlueFox
    LOL. True. :)
  • maxward
    maxward Posts: 1,683
    My AC-9 is back in the box for that very reason.
