Do I need a sub with these Usher MD2's?
@Derf, good point but this would be a stop gap, cant afford to go big. Anyway I would like some opinions regarding my theory.
@Derf, are you running an upgraded power cable to your sub?
Using stock power cable.afterburnt wrote: »@Derf, are you running an upgraded power cable to your sub?
Integrated Amp: Marantz PM-10
Speakers: Usher MD2
Subwoofer: Rythmik F15HP
DAC: North Star Design Supremo
Streaming Source: AURALiC Aries Mini
SACD Player: Marantz SA8004
Power Source: PS Audio PP3 on dedicated 20amp circuit -
Gotcha. The bass should be similar but more controlled compared to the N-6361. You can always add a sub to a speaker system to get a little more weight to the music. Need? I don't think so. Gains? Always.
One reason I liked you going with the Preamp instead of another route is that you get dual pre-outs so its easy to integrate a subwoofer if you choose so later on. I think if you haven't yet, room treatments should come before a subwoofer as controlling the energy in a room has big rewards on the entire frequency range.
@DSkip "dual pre-outs" ? I don't get it, please elaborate.
I thought I would have to use the speaker outs??? -
afterburnt wrote: »Gotcha. The bass should be similar but more controlled compared to the N-6361. You can always add a sub to a speaker system to get a little more weight to the music. Need? I don't think so. Gains? Always.
The preamp has two different pairs of pre-outs. You can use one set for the amplifiers and another set for the subwoofer.
Oh yeah would you look at that!
So I am supposed to run RCA cables to the LFE input?
Are these not left and right outputs? So how do I hook up one sub? -
afterburnt wrote: »afterburnt wrote: »Gotcha. The bass should be similar but more controlled compared to the N-6361. You can always add a sub to a speaker system to get a little more weight to the music. Need? I don't think so. Gains? Always.
Never mind, I found some pictures.
