PSW505 12-Inch Powered Subwoofer - Dead on arrival
DanZ
I have just received my brand new PSW505 subwoofer - unfortunately it will not power on at all ( the light at the back does not light up in any color ).
I have tried switching power sockets and checked the cable with voltage meter while plugged into socket - all OK , I also tried changing switch positions at the back panel- but the sub just wont power on no matter what I do.
Help!
Help!
This may be obvious, but there is a main power switch right above the AC plug... And there should be a fuse right below it.
Power switch was turned on, no fuse accessible from back panel
Correction - found the fuse drawer - fuse is busted - will replace tomorrow
Right - changed busted fuse - now enjoying deep bass from my PSW505
Whats odd was that it was supplied with a busted fuse - or the fuse burned when first plugged in.
Fingers crossed there wont be anymore electrical issues -
Glad it was an easy fix. Enjoy for years to come!
So long as the house remains in place with all the wall trembling - I'm most certain that I will
