LSiM703 and LSiM702F/X which to use for surround vs rear surround
whostorm05
in Speakers
So I'm going to use a part of LSiM702F/X and LSim703's for surround vs rear surround in a 7.1.4 setup. I keep going back and forth on if I should use the LSiM702F/X as the surround or rear surround speakers. At first I thought about putting the LSiM702F/X slightly ahead of main listening position with the tweeter pointing to the listening position. Then I thought about using them as the rears mounted on the rear wall with the tweeters pointing into the room towards the main listening position.
Any thoughts?
Any thoughts?
702 for sides
703 rears2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Looking at the layout suggestions and the fact that Dolby does not recommend Dipole speakers for ATMOS....I think you are good either way...meaning both will work in either position. So, given that the sides should be on axis with this listener maybe use the 703s on the sides. Then put the 702s in the rear at the proper distance apart to get the desired projection angle of the Sonic engine drivers to listening location as in the Polk diagram.
Here's a pic of the room as well.
The real show starts when you step on those wire cutters in the dark and stub your toe on the front sound stage ladder.I disabled signatures.
Yep, just move the 703 to the sides then put the 702s on the rear walls.2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
How high would you guys mount the 702s on the rear wall? The 703's are on 36 inch stands. Considering I'm going to do 4 in ceiling atmos speakers should I keep the 702's about the same level as the 703's?
Here's a pic of the front sound stage minus the ladder. lol I haven't decided on final placement of the sub yet. -
Dolby lays it all out...
https://www.dolby.com/us/en/guide/dolby-atmos-speaker-setup/7-1-4-setups.html
"You'll get the best sound when the front and surround speakers are at or slightly above your ear level when you're seated. Wall-mounted surrounds can be higher, but no speakers—especially Dolby Atmos enabled modules—should be higher than half the height of your wall.
The angles shown in all diagrams represent the ideal placement range relative to your listening position.
Ceiling Height and Materials
The ideal ceiling height is between 7.5 and 12 feet, and the maximum recommended height is 14 feet. The ceiling should be flat and made from an acoustically reflective material, such as drywall or plaster."
The ideal ceiling height is between 7.5 and 12 feet, and the maximum recommended height is 14 feet. The ceiling should be flat and made from an acoustically reflective material, such as drywall or plaster."[/i]
I wonder if that part is only relevant to upward firing atmos speaker modules? If the speaker is ceiling mounted why would it matter if the ceiling is acoustically reflective?
My ceiling is 11.5 feet high so that shouldn't be an issue either way.
Not to derail the thread but noticed you had the Artison Portrait LRS. Are you happy with these? I've been shopping around for some rears in a 5.1 setup and these would blend in with the grey wall vs the 702's much smaller profile and wife approved. Doesnt seem like you can buy these anymore but they look fantastic! Just picked up a 705 and 706c and shopping around for the rest.
These Portrait LRS speakers were $500 retail and are small good looking speakers. That however only tells part of the story. They have a large diffused uncolored sound and are a great option for those wanting unobtrusive wall mount speakers. They use quality Vifa drivers are worth the purchase if a used set pops up. I paid about $90-$100 for my set used some years ago. They worked great with LSiM703/706C, Chane, Polk RT, Boston Acoustics speakers I've had since I've had over the years.
It looks like Crutchfield still have the in-wall versions available but they are $699.99!2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
