New polkie
Im new here from minnesota and just scored Sda 2bs for $300 with cable, i love them. also scored some 7s for 60 bucks, which i love as well.... And 2 pair 10s...a pair Rta 8tls (my first polkies) and a pair of 5s and 5jrs... Can say im addicted.. Just stopping in to say hello! Will be doing alot of resto and mods in the future but for the time being every pair is functional and appear to be original.
Monitor 4.6, 5jr, 5, 7, 10, 11. RTA 8TL. RTA 11T. SDA 2B.
    txcoastal1 Posts: 13,505
    @mn_polk_guy, Welcome.....
  • mn_polk_guy
    mn_polk_guy Posts: 102
    7s and sdas
  • mn_polk_guy
    All the others.. Not actual listening placment for any of these
  • mn_polk_guy
    Im In an apartment right now, moving into a house may 1st.
    Nice family, congrats on your purchase and good luck with the move
    EndersShadow Posts: 17,698
    Welcome to the jungle, the rabbit hole, the endless time suck...... we are that and so much more.....
  • verb
    verb Posts: 10,176
    Welcome to Club Polk! I joined back in December with a set of 2B's as well. Since then, I now have 2 sets of 1C's one stock except for the tweeter upgrade (easy to do), and another WIP fully modded set! Oh yeah my 2-channel rig is completely transformed with the help of Polkies!
    Lot's of roads to go down with your 2B's - have fun! :smile:
  • mlistens03
    mlistens03 Posts: 2,767
    Welcome to the forum!
  • GlennDog
    GlennDog Posts: 3,150
    Welcome!
    Last Nov a Polkie from Minnesota drove to the Detroit area to buy my 2.3TLs. We loaded him up and he drove home same day! He goes by PKQUAT
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • verb
    verb Posts: 10,176
    GlennDog wrote: »
    Welcome!
    Wow! And I missed them by just a month! :smiley:
  • mn_polk_guy
    So on one of my sda's i have a pin hole in the passive. Can it be repaired or should i find a new one?
  • mn_polk_guy
    Picture of my passive
  • mn_polk_guy
    Appears i may have some dry rot... Damn.
    audioluvr Posts: 5,892
    Fix it
  • FestYboy
    FestYboy Posts: 3,861
    Repair it. If you can reach it from the inside, scuff the surface and apply a rubber weld with a q-tip. The repair will be invisible. The weld should contact the fissure walls as well as the stuffed surface. Use as little as is necessary.
  • mn_polk_guy
    edited April 2018
    I pulled it just to peak. looks repairable ill give it a shot...and keep an eye out for an extra 121.
  • verb
    verb Posts: 10,176
    FestYboy wrote: »
    Rubber weld as in bicycle tube patch glue?
  • mn_polk_guy
    Any brands? 3m scotch weld?
  • teekay0007
    teekay0007 Posts: 2,289
    Welcome, mn_polk_guy, to Club Polk, form another MN Polkie!
    I think I may have seen those 2Bs recently on CL(?). Are they the pair with the minor water stain on the top end cap?
    You look like you got well down into the Polk rabbit hole prior to your arriving here. I did it the other way around, just had my Monitor 10Bs before joining. Since then, I've got Monitor 7 (IIs), 5Jr+s, VM10s (surrounds), CS400i (x2), SDA-1Cs, LSiM703s and a pair of DSW-550i subs.
    AND...Monitor 7Cs, 4s, 5Jrs; RT12s; VM30s, 20s and 10s; LSi7s, 9s, FXs and 15s; R50s; PSW10 and 110; RM8000Ts, 7300Ts, 7302s; DSW-3000 and 2000, etc., etc. have all moved through here at one time or another, to name a few.
  • FestYboy
    verb wrote: »
    FestYboy wrote: »
    Yup! Designed to repair neoprene and vulcanized rubber and remain flexible.
  • mn_polk_guy
    Yes thats the pair, guy almost didnt part with them. Everything functions great but will need some refinishing. Im supposedly the third owner of the pair.
  • mn_polk_guy
    I use this stuff at work for tire patching(car tires).
  • FestYboy
    I'd ask a local bike shop what they recommend first...
