Driver mounting with 8-32 hurricane nuts
Pre drill size ? Is it 3/16” ?
    F1nut Posts: 51,880
    You don't pre drill, you draw the h-nuts into the original holes with the screw and washer.
  • westmassguy
    westmassguy Posts: 6,850
    The hole size is 13/64" for the 8-32 size nuts. Don't drill out the holes with that size immediately. I use three drill sizes to enlarge the hole gradually. Start with 1/8", then 5/32", finishing with the 13/64". This prevents splitting the particle board, or worse, blowing out a chunk of material on the back side. Lay the cabinet on its back, on a level surface. The 1/8" starter bit will follow the original screw hole. Use low speed, and don't apply any pressure to the drill, let the weight of the drill make the hole, and check the level bubble if your drill has one. Do all the holes with the 1/8", then move up to the 5/32" and so on. Next, I use a 3/4" or 1" wood chisel to clear any burrs off the back side of the holes. You may find excess hot glue where the holes are drilled. This will need to be removed. you can use a heat gun, or hair dryer set on high to soften the hot glue, the peel it away with the wood chisel, and trim it off. To set the Hurricane Nuts, I use a small 1/2" diameter washer, and a couple of sacrificial screws. Put the washer under the head of the screw, hold the hurricane nut to the back of the hole, manually start threading the screw, and finish with the drill with a Phillips bit in it. Use low speed, and you'll know when the Hurricane Nut is seated by the sound of your drill. The washer helps prevent the screw head from sinking too far into the particle board as its pulling the Hurricane nut up into the hole. The H Nuts should be installed on the Tweeter, Woofers, and Passive Radiator. You do not need to install them on the Binding Post Cup. The Cup only receives air pressure fluctuations, and doesn't produce any mechanical stress like the other components do.See this thread for photos: http://forum.polkaudio.com/discussion/149215/monitor-10-rebuild-with-tl-mod/p1
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    F1nut Posts: 51,880
    Hmmm....I don't remember drilling out the original holes, but I'm old.
  • ThomasD
    ThomasD Posts: 260
    Not to interrupt but was wondering if any of the drivers require a 10-32
    H nut and what length bolt, 1" or 1-1/4 ?
    Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM
    F1nut Posts: 51,880
    No and 1 inch is plenty.
  • bassfann
    bassfann Posts: 151
    I did my 1 speaker today. Yeah,I pre drilled and all went smoothly.
  • bassfann
    bassfann Posts: 151
    I was surprised that PE didn’t have black 8-32 pan head screws,but I bought them from Amazon.
  • westmassguy
    Seasoned, Jesse, seasoned...
  • westmassguy
    bassfann wrote: »
    I use the TORX pan heads on the woofers and PRs, no worry about slippage. I use hex, flatheads on the tweeters, they fit flush with the recessed mounting holes. I replace the Philips on the tweeter also with hex, flatheads. Makes everything neat and tidy.
    F1nut Posts: 51,880
    I use socket cap screws because they look bada$$, not to mention they are what Polk used on the SRS, 1.2 and 1.2TL.
  • bassfann
    bassfann Posts: 151
    All drivers mounted,using mortite caulk cord to seal them. I don’t know how well they’re sealed,though. I push on the PR to see how long the other drivers take to return but I haven’t timed them.
  • verb
    verb Posts: 10,176
    F1nut Posts: 51,880
    bassfann wrote: »
    Big mistake using that material.
  • verb
    verb Posts: 10,176
    There seems a time in CP when Mortite was all the rage but do to the serviceability issues it's not the favored sealant anymore.
    Armacell is now preferred!
  • bassfann
    bassfann Posts: 151
    bassfann wrote: »
    Does it harden ?
  • verb
    verb Posts: 10,176
    bassfann wrote: »
    bassfann wrote: »
    Does it harden ?
    Yup. Kinda like glue. Horror stories out there of the MDF separating upon removal. :cry:
  • bassfann
    bassfann Posts: 151
    verb wrote: »
    bassfann wrote: »
    bassfann wrote: »
    Does it harden ?
    Already done.
  • verb
    verb Posts: 10,176
    bassfann wrote: »
    verb wrote: »
    bassfann wrote: »
    bassfann wrote: »
    Does it harden ?
    Already done.
    If you just applied the Mortite recently, not too late! Probably not rock hard yet.
  • bassfann
    bassfann Posts: 151
    bassfann wrote: »
    verb wrote: »
    bassfann wrote: »
    bassfann wrote: »
    Does it harden ?
    Already done.
    Should stay sealed though,right ?
  • verb
    verb Posts: 10,176
    bassfann wrote: »
    bassfann wrote: »
    verb wrote: »
    bassfann wrote: »
    bassfann wrote: »
    Does it harden ?
    Already done.
    Yep. It seals good. Some Polkies still use it. In the future you may run into trouble!
    F1nut Posts: 51,880
    bassfann wrote: »
    bassfann wrote: »
    verb wrote: »
    bassfann wrote: »
    bassfann wrote: »
    Does it harden ?
    Already done.
    There's more to it than a good seal. The basket rim needs to be in solid contact with the mounting bezel. That's why the original gaskets are paper thin. A product like Mortite creates too much of a cushion. Remove it and use the speaker gasket material from Parts Express or if you have to, Armacell.
  • bassfann
    bassfann Posts: 151
    verb wrote: »
    bassfann wrote: »
    verb wrote: »
    bassfann wrote: »
    bassfann wrote: »
    Does it harden ?
    Already done.
    Installed today
    Toolfan66 Posts: 18,122
    My vote is get rid of it...
  • gp4jesus
    gp4jesus Posts: 2,019
    nbrowser wrote: »
    I DO remember drilling out the original holes and I’m old. Further, like above I took a gradual approach too. In the process, I discovered, the final drilling w/a 1/64” larger bit makes the install MUCH easier. I used a few H nuts to secure my LFE sub* amp to its closure, too
    * B1.39
    My 2 cents.
    *all connected w/Premiere ICs
  • bassfann
    bassfann Posts: 151
    Guess I’m removing it in the morning
  • bassfann
    bassfann Posts: 151
    How long does it take to dry ?
  • gp4jesus
    Please accept CORRECTION to my post?
    I DO remember drilling out the original holes and I’m old, too. Further, like another above I also took a gradual approach. In the process, I discovered, the final drilling w/a 1/64” larger bit makes the install MUCH easier. I used a few H nuts to secure my LFE sub* amp to its closure, too
    * B1.39
    My 2 cents.
  • bassfann
    bassfann Posts: 151
    verb wrote: »
    bassfann wrote: »
    verb wrote: »
    bassfann wrote: »
    bassfann wrote: »
    Does it harden ?
    Already done.
    verb wrote: »
    bassfann wrote: »
    verb wrote: »
    bassfann wrote: »
    bassfann wrote: »
    Does it harden ?
    Already done.
    verb wrote: »
    bassfann wrote: »
    verb wrote: »
    bassfann wrote: »
    bassfann wrote: »
    Does it harden ?
    Already done.
    verb wrote: »
    bassfann wrote: »
    verb wrote: »
    bassfann wrote: »
    bassfann wrote: »
    Does it harden ?
    Already done.
    Installed today
  • bassfann
    bassfann Posts: 151
    verb wrote: »
    bassfann wrote: »
    verb wrote: »
    bassfann wrote: »
    bassfann wrote: »
    Does it harden ?
    Already done.
    verb wrote: »
    bassfann wrote: »
    verb wrote: »
    bassfann wrote: »
    bassfann wrote: »
    Does it harden ?
    Already done.
    verb wrote: »
    bassfann wrote: »
    verb wrote: »
    bassfann wrote: »
    bassfann wrote: »
    Does it harden ?
    Already done.
    verb wrote: »
    bassfann wrote: »
    verb wrote: »
    bassfann wrote: »
    bassfann wrote: »
    Does it harden ?
    Already done.
    Installed today
    F1nut Posts: 51,880
    WTF?
