For anyone who might be interested: Nelson Pass-designed ACA amplifier kit "back in stock" :)
24
    mhardy6647 Posts: 27,257
    They did a good job with 'em, too -- I really didn't do very much of the work. I did smoke test 'em, though. They were a little young to really be ready for working with lethal B+ voltages on the plates of the 2A3s!
  • verb
    verb Posts: 9,809
    no triodes in an Amp Camp Amp :)
    Three "elements" in a transistor, but it just ain't quite the same thing ;)
    If you want to dip your metaphorical toes into the SET water, here're a couple of nice options. L'il pricier, though.
    https://bottlehead.com/product/single-ended-experimenters-kit-3-for-headphones-sensitive-speakers/
    (Compactrons, baby!)
    https://bottlehead.com/product/stereomour-ii-stereo-single-ended-integrated-2a3-amp/
    What do you think of the Bottlehead SEX amp?
    Basement: Polk SDA SRS, Cary SLP-05 Pre with ultimate upgrade,Enlightened Audio Designs CD Transport, Northstar Designs Excelsio DAC, Cambridge 851N streamer, Marantz SA-14 SACD, McIntosh MC300 Amp, Silnote Morpheus Ref2 Digital Cables, Furman 15PFi Power Conditioner, Pangea Power Cables, Wireworld Oasis 8 RCA IC's, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
    Office: PC, EAR Acute CD Player, EAR 834L Pre, Northstar Designs Intenso DAC, PASS ACA Monoblocks, Denon UDR-F10 Cassette, Acoustic Technologies Classic FR Speakers, SVS SB12 Plus sub, MIT AVt2 speaker cables, IFI Purifier2, AQ Cinnamon USB cable, Groneberg Quatro Reference IC's
    Spare Room: Antique Sound Labs Wave AV-8 Monoblocks, Tisbury Mini Passive Pre, Tjoeb 99 tube CD player (modified Marantz CD-38), Analysis Plus Oval 9's, Zu Jumpers, AudioEngine B1 Streamer, Klipsch RB-61 v2, SVS PB1000 sub, Blue Jeans RCA IC's, Shunyata Hydra 8 Power Conditioner
    Garage: Cambridge Audio 640A Integrated Amp, Project Box-E BT Streamer, Polk Tsi200 Bookies, Douglas Speaker Cables, Shunyata Power Conditioner
    edited March 2018
    verb wrote: »
    I haven't heard the current iteration -- I heard the original way, way back in the late 1990s. It was pretty respectable -- the 2A3 amplifiers outperformed the original, though, in every respect (as they should). They cost more, too, though.
  • verb
    verb Posts: 9,809
    edited March 2018
    @mhardy6647 I got an eye on a built one circa 2007.
    edited March 2018
    Got some 95+ dB sensitive loudspeakers with a benign impedance curve to match with it? If so -- go for it.
    or
    buy the amp and use it as an excuse to get some high-sensitivity loudspeakers.
    bwahahahahahahahahahahhhhaaaaaa!
    (or use it as a bitchen headphone amp)
  • verb
    verb Posts: 9,809
    What do you think of the Klipsch reference RB-61? 95db sensitivity.
    Clipdat Posts: 9,536
    I would go higher in the Klipsch food chain before going for those.
    verb wrote: »
  • verb
    verb Posts: 9,809
    Clipdat wrote: »
    verb wrote: »
    Klipsch has got the RB-81's on sale right now for 279/each! 98db sensitivity.
  • vcwatkins
    vcwatkins Posts: 1,993
    My goal with the ACA buy is to try full range single drivers, but I wouldn't mind also trying efficient 2-ways. So, my questions are:
    Any recommendations on single drivers and corresponding plans or kits? If I build something, I would prefer narrow baffle width and smallish footprint generally. I don't mind going vertical 8' or less. Simple is better and basic plywood is cool. I do have a shop and tools but don't have a lot of floor space in the listening room. Maybe Frugel-horns? I don't want to spend untold hours on this - I just want to whip up something basic and see how I like the low power approach.
    Opinions on how Zu Omen's might match up? Other Zu's?
    Other systems - either single driver or 2-way - for <$800ish used? I don't have much floor space, so corner horns are not possible.
    I do have pairs of Hartley 220MSG 10" and 207MSG 7" FR (ferrite, not alnico), but they're packed up to sell and I sorta doubt they're efficient enough anyway. Here is an interesting system, but I think I would prefer something without a crossover. Looks like I'd need to add a phase plug somehow too. Any thoughts/experiences?
    Thanks for any help,
    Craig
    Study: Roon * ProJect Stream Box Ultra & Pre Box S2 * Pass ACA * DH Labs SS Q10 * Brines Folded ML-TQWT RS 40-1354
    Audio: PS Audio DirectStream Jr. * Belles 20a * Pass Aleph 30 - Zu Omen DW * Sunfire Sig II - Polk SRS 2.3tl * PSAudio PP3 * MIT S3
    Den: Sonore ultraRendu * Cary xCiter * Dayens Menuetto * KEF LS50
  • verb
    verb Posts: 9,809
    or
    Found this article interesting:
    https://www.dhtrob.com/overige/tubefriendly_lsp_en.php
    vcwatkins wrote: »
    Craig
    How much of your money would you like us to spend? :)
    For all-in kits, Fostex has some cool ones; check www.madisound.com
    For cut-your-own... well... a folded, tapered TQWT (or a non-folded one, if you have the vertical clearance) is relatively straightforward to build (well, not for me -- nothing's pretty when I build it!) and is capable of good performance with myriad drivers.
    You've doubtless seen my Bob Brines designed folded, tapered mass-loaded TQWTs loaded with the venerable Radio Shack 40-1354 twincones, yes? If not, they look like this...
    9599007591_1f3e441faf_b.jpgDSC_6399 by Mark Hardy, on Flickr
    12289315386_cf252f4e11_b.jpgDSCN5289 by Mark Hardy, on Flickr
    I had these enclosures built for me from Baltic birch plywood, BTW.
    I would expect the Zus to be a reasonable match -- they do tend to (heh-heh) polarize people. Tekton, if memory serves, has some pretty sensitive and simple loudspeakers, too (as well as some non-simple ones).
    Also, you might want to think about a full-range driver (ahem - let's be honest: "extended range" driver) with a supertweeter. Get a nice, sensitive sweet sounding tweeter (there're quite a few options, new or vintage, at many price points) and cross it in very high first order with a good quality capacitor and an L-pad to adjust to taste.
    Does any of this help any?
    edited March 2018
    verb wrote: »
    or
    TL;DR ;)
    In seriousness -- at a quick glance, it looks like it makes some of the points I like to reinforce about matching loudspeakers to amps with high output impedance (low damping factor). I didn't see anything clearly and blatantly wrong or stupid, so the prognosis is good. :)
    I'll peruse anon; thanks for providing the link.
  • Jim Shearer
    Jim Shearer Posts: 368
    I am a single driver fan myself, but they are not for everyone. Single driver speakers will not give you ear bleed SPLs, nor can they produce chest thumping bass. If you can accept their limitations, then you may find that the right single driver speaker can deliver a mid-range goodness that is only equaled by the finest multi-way speakers, but at a very modest cost.
    You mentioned Frugel Horns. That might be a nice build! I can recommend the Frugal Horn XL for the Alpair 10.3 driver as a good choice. And Madison has the A 10.3 on sale now:
    https://www.madisoundspeakerstore.com/approx-6-fullrange/markaudio-alpair-10-gold-6-full-range-gen-2/
    Or, if you want something smaller, the Frugel Horn mk3 with the Alpair 7 might do.
    If you chose either of these drivers, there are serious caveats about break-in and installation. Some users have complained about driver failure which IMO was entirely due to operator error. I can elaborate if you want to pursue these drivers.
    If you want to try a really cheap project, there is a project on DIYaudio.com using either dual Vifa TC9FD-8 or single Dayton PA-130-8 drivers in a Karlsonator style box built with foam core board!
    Keep us posted!
    Cheers, Jim
    A day without music is like a day without food.
  • vcwatkins
    Wow, thanks @mhardy6647! Very helpful. Much reading to do.
    Single Full Range
    I picked up a pair of 40-1354a's for $32 and am thinking maybe a non-folded ML TQWT, although I prefer the proportions of your folded ones. I do have some birch plywood but it's 3/4 I think. Did your builder use 1" or double-up? They look very substantial.
    Tekton's
    I really would like to try the Double Impact, but paying $3k AND waiting months for delivery makes it much much less appealing.
    Zu's
    I think I'll monitor on-the-line for used Omens and buy if there's a very good value.
    Supertweeters
    I will read up and may try adding later.
    Thanks again for all the info.
    The cabinets are 3/4 inch on the folded TQWTs.
  • vcwatkins
    Gotcha, thanks.
  • mrbiron
    mrbiron Posts: 5,599
    If Mr Hardy lets me borrow his ACA, i’ll tell you exactly how the Omens work with her ;)
    I keep making excuses why i CAN’T drive up to him.
    “If your eyes didn’t water, it means I didn’t go deep enough” says the nurse administering my COVID19 test. She was sweet...
    It is kind of our (the Forum's) ACA, not mine per se -- and it's warmed up and waitin' to go to your abode at our earliest mutual opportunity (or shipped in a box, if necessary)!
  • vcwatkins
    Keep us posted!
    Cheers, Jim
    Somehow missed this post. Many thanks for the great suggestions, Jim! I'll look into those.
    vcwatkins wrote: »
    Keep us posted!
    Cheers, Jim
    You got distracted by my drivel :|
    Yes, a bunch of good info in Mr. Shearer's posts!
  • maxward
    maxward Posts: 836
    This is exactly like I hoped that this thread would evolve. Lots of good information about appropriate speakers to mate with the ACA. Unfortunately, it appears that only a couple of us were able to snag one of the latest kits. Let us know how the builds go.
    I am using these with the ACA, in case that wasn't obvious.
    24051079897_d03eddae1b_h.jpgDSC_9984 (3) by Mark Hardy, on Flickr
  • voltz
    voltz Posts: 5,386
    edited March 2018
  • verb
    verb Posts: 9,809
    @mhardy6647 newbie question. Other than sounding anemic, presumably, at low or moderate volume levels (avoid amp clipping), is there risk of running lower efficiency speakers on a low power SET amp?
    Just a placeholder until I get some higher efficiency ones of course! Please advise.
  • ken brydson
    ken brydson Posts: 8,043
    If I had a nickel for everytime I saw that pic I'd be a gazillionaire... B)
    verb wrote: »
    Not really. A SET will start to sound congested/strained as it slides into nonlinearity. It can be fairly unpleasant with the wrong recording :/
    If didn't have all that junk, maybe I would be too.
  • george daniel
    george daniel Posts: 12,072
    edited March 2018
    Is that a Sony Slant deck? 366?
  • BlueFox
    BlueFox Posts: 14,306
    Are you calling my Bryston DAC junk? :)
    Did you ever use it?
    Lumin X1 file player
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
    TC-377
    Dump find. Works well (except the counter belt needs to be replaced)
    Decent sounding basic mechanical transport, single motor, three-head deck. Good for auditioning found tapes. :)
    16102128209_95e707b923_h.jpgSony TC-377 by Mark Hardy, on Flickr
Howdy, Stranger!
