My awful experience with Polk customer service.
Where the crack in the circuit board, take a knife and gently scrape off the green coating over the copper.
Take a wire, solder it to each side of the crack along each section where it is broke. Do this to any section that would otherwise be connected.
Fixed, the end.
So if you do this to fix a cracked board, does it matter if its solid or stranded wire??Denon AVR X4200W
Parasound A23 amplifier
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Denon DP 3000 turntable
Saec 308sx tonearm w/
Dynavector 10x5 cart
Vincent PHO 701 Phono Preamp
MIT Avt3 Speaker c's
Audio Quest Big Sur ic's
Polk SDA 1C's modded
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Polk DSW PRO 440wi sub
Infinity bu2 sub
"The early Klingon gets the Gagh" -
Shouldn't matter, I've done both depending on where the repair is being done. Most times I'll flow a solid strand to help brace the board. In some cases, I've drilled the trace and placed the repair on the back side of the board if it made the repair easier to manage. Quality solder is the key here.
Noted!! Thank You.Denon AVR X4200W
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Infinity bu2 sub
Just wanted to update this! After going through my old emails I realized that I missed a email from Polk back in late march about parts being available now. Awesome news! I'm now pretty excited about the possibility of getting my speaker working so fingers crossed and I'll update this later!
I haven't been around much but you did sound like that guy XCapri a lot. He's gone way long time now.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
