Karma?
Yeah, I hate to say it, but I think they are right. Toss it.
Nah... Im always up for a challenge. Bring it on!
For punishment? You bet!!
Agree that this one is beyond hope, given the cost to fix versus riskThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »Agree that this one is beyond hope, given the cost to fix versus risk
Test on cr@ppy speakers because likely something may blow2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Capacitor blew and started a fire, that the owner then used water to extinguish. Then it sat for an undetermined amount of time.
Then it was powered up again and started smoking. Now here it is. -
I think I’m out, number 75 is free for anyone to take.
Random number generator will be ran this evening. Last call for anyone interested.Pro-ject 2 Experience SB, OPPO BDP-103, Marantz SR5011, Lounge LCR MKIII, McCormack DNA-HT5, Polk LSiM705, Polk LSiM706C, Polk LSiM702, SVS SB16-Ultra
I knew something was wrong with the color of the PCB!
Just junk it @dr1978This thing looks like it got wet and or sat out in the garage or a damp basement for some years.
Here are some photos of some others: http://www.ukaudiomart.com/details/649391951-parasound-hca1200-power-amp-205wpc/images/1695769/
http://www.usaudiomart.com/details/649100007-parasound_hca1200_high_current_power_amplifier_excellent_condition_200_wpc/images/677195/
http://www.hifishock.org/gallery/electronics/parasound/power-amplifier/
Eh, if someone finds value in it, no skin off my back. I can handle a trip to the UPS store.Pro-ject 2 Experience SB, OPPO BDP-103, Marantz SR5011, Lounge LCR MKIII, McCormack DNA-HT5, Polk LSiM705, Polk LSiM706C, Polk LSiM702, SVS SB16-Ultra -
I would worry with the rust on the toroidal cap. I bought new old stock transformers from Parasound and came like that, due being a couple decades on a warehouse.
It’s funny, I had a Parasound dac arriving with the same problem. Two of the three transformers were ripped off the board from an impact during shipping. Luckily I pop the cover off before powering it.
That’s a great amp, totally fixable. I would inspect for anything shorting, probably the bottom of a board touching the chassis or small black heatsink touching resistor legs.
Power it again with a dim bulb tester to see here the smoke is coming from.
I'm going to respectfully remove myself. It does look like more than I'd want to tackle.
Thanks for the option. Good karma to you! -
In with 4, why not.
@WLDock are you still in? #67 popped up, putting you first up. If so PM me your address and I'll get a shipping estimate.
Then la2vegas at 42 and festyboy at 4. I think everyone else has dropped out.Pro-ject 2 Experience SB, OPPO BDP-103, Marantz SR5011, Lounge LCR MKIII, McCormack DNA-HT5, Polk LSiM705, Polk LSiM706C, Polk LSiM702, SVS SB16-Ultra -
@WLDock interested?Pro-ject 2 Experience SB, OPPO BDP-103, Marantz SR5011, Lounge LCR MKIII, McCormack DNA-HT5, Polk LSiM705, Polk LSiM706C, Polk LSiM702, SVS SB16-Ultra
PM'ed2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
Good luck fixing it!
yeah looks like something I would expect from fed ox/up in my neck a the woods / they delivered a package that said please place on front porch as address line 2 and merely dropped my wingtime hotsauce over a 3 foot fence on its side...at least I figured wally whirled packs 2 cases better than one and second go around the 3 foot drop on its side was more forgiving. hashtageverybottlebustedwith6nonewith12Onkyo TX-NR636
Main - polkaudio Monitor 60's
Center - polkaudio CSI A6
Sub - polkaudio PSW10
Sub2 - polkaudio PSW505
Surrounds - polkaudio Monitor 40 series II
Front Height - polkaudio Monitor 40's
Audio Outdoors
Pioneer VSX 406 - polkaudio Atrium 5
Shed
Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
Shed 2
Nakamichi soundbar -
Maybe he tossed it?2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
Sorry for slacking wldock, it's been hectic around the house lately. I'll get back with you by Tuesday at the latest.Pro-ject 2 Experience SB, OPPO BDP-103, Marantz SR5011, Lounge LCR MKIII, McCormack DNA-HT5, Polk LSiM705, Polk LSiM706C, Polk LSiM702, SVS SB16-Ultra
Sorry to bump an old thread but @WLDock did you ever fix it? I would be interested to know, and probably others would be too.
I received it a few weeks ago and tore it apart the day I received it. The first sign of trouble was the fact that this thing took some major shock at some point. The AC power supply board with the four large caps has several (6-10?) cracks. Also, I can smell burnt electronics but could not see anything obvious. So, this one will take some time and it got put on my back burner. I still have inside house projects as well as the outside projects now that its finally warm. Also, I have two sub amps, and one maybe two AVRs to repair before it. I'll keep chipping away at it and will take my time trying to fix the board. Some spots are so bad that I will have to epoxy the board and band the traces. Its a long shot but it will be fun if I can get this thing going....however this is a pretty old amp and replacement part cost could add up quick so we'll see....Ill keep you guys updated.
Goodness, it looks pretty rough up close, good luck!
