Help with system.
Thank you☺️
Hello everyone... hope all well ... just got delivered Polk CSIa6 yesterday..... Just trying to make some open space for 3070... will keep you posted .
You've got the upgrade bug! You fit in well around here, haha.
Nice looking center channel!Hello everyone... hope all well ... just got delivered Polk CSIa6 yesterday..... Just trying to make some open space for 3070... will keep you posted .
Thanks a lot Clipdat ☺️☺️
Hey All ....My 30 Years old Sony speaker
Iam so sorry clipdat ... I think dad purchased in 1980
I think dad has changed the twitter a year back as he was not able to find the twitters of same size anywhere .... the 8 inch speaker is original
Oldschool gear!
Does that woofer have an inverted surround? Ahh I always think that that is just sooo cool
Those amps and the EQ also look pretty nice, I love the look of that old school gear -
Does everything still work? How's it sound?
Thank you Mlistens...no it does not have inverted surround.... however bass is too good in this setup with clean tone ... however you will not get wall shaking bass but still it will challenge other current systems ☺️☺️
Yes Clipdat ... perfectly for fine ... EQ makes sound quality amazing ☺️☺️
Hi All .... Just tired to make Little more space for 3070 for time Being- took it to iron cutter shop and removed the middle barricade... overall I think now the space is more the 6inch .. this was done to fix CSIa6 on top ... is this fine ..?
And also, 3070 is slightly cross towards right side, Little down less then 1/2 inch ... but all the foots are correctly set on the bottom ..is that fine .. thanks
I would say 6 inches is probably fine, but I’m not a expert on amplifiers, and I’ve never had to deal with this kind of issue, so I’d check with the other guys
Thanks a ton mlisten..☺️
mlistens03 wrote: »I would say 6 inches is probably fine,
LOLOLOLOLOL -
That is good.Political Correctness'.........defined
President of Club Polk -
Yep, looks good!
Cool ... thanks a ton F1nut and clipdat... now I can breath peacefully for sometime ☺️☺️
And so can your receiver.
Ha ha ha ha Viking....very true
Good move getting the CSiA6
Greetings from Russia!
I do not quite understand what you're talking about here, but nevertheless decided to say hello
Woah dude, what’s going on behind your tv! Is that anew thing? I don’t know that I’ve ever seen that before.
