12" momo in a .75cuft sealed enclosure
bam88
How much poly fill should i use any tips on that to optimize the stuffing?
Maybe the matted kind they use for quilting?
Post edited by bam88 on
If you look up the recommended designs for the sub it should say how many pounds of fill. Some one at the car audio section may know more about your driver. You can use the kind they use for stuffing. It's call Polyfil, it usually comes in a roll.Graham
