Spikes vs Slabs
    Viking64 Posts: 7,608
    Spikes vs. Slabs? That sounds like a hockey game. Or maybe Rollerball?
    F1nut Posts: 51,941
    Bruce, Home Depot or Lowe's sells them.
    audioluvr Posts: 5,982
    afterburnt wrote: »
    I was sweating like a slave wrestling with the speakers to place those damn disk without messing up the floor!
    If you get the 2 part spikes like shown above you don't put the points on until they are in final placement. Then tip for install. Also if you are on hard floors I've been happy on some speakers removing the little metal or plastic feet and just set the speakers flat on the floor.
  • afterburnt
    afterburnt Posts: 7,892
    @audioluvr it would have been easier if I could see. Aligning that little divot by feel is a female dog.
    Ya, i usually get a buddy to help on stuff like that. Lately my daughter has been fascinated with helping...
  • DarqueKnight
    DarqueKnight Posts: 6,765
    For larger spikes I like the Adona Multi-Element cones. Adona also has a number of other spikes available.
    Thanks. I really like the selection on the Adona site.
    F1nut Posts: 51,941
    I thought you would.
  • FestYboy
    FestYboy Posts: 3,861
    afterburnt wrote: »
    afterburnt wrote: »
    GlennDog wrote: »
    A speaker with a passive radiator is NOT an acoustic suspension speaker.
    Spikes are used to transfer cabinet vibrations to the floor in turn cleaning up the mid-range and tightening the bass response.
    So mini-saucer/floor protectors (under spikes) do not reverse the affect? They still bond with floor?
    The spikes are like an energy transfer conduit, so with the discs the energy is transfered to them and then the floor. Some discs have a thin felt pad on the bottom, which is fine. I've seen others with a thick carpet like pad, which somewhat defeats the purpose of using spikes, so I'd avoid those.
    What about miniaturized rubberized pads?
    Those would decouple instead of couple.
    ... Where would one find little felt pads?
    Maybe this is why they don't sound so good?
    Wally world... In their crafting department. Thin, self adhesive felt sheats in several natural colors (earth tones). $5 for a 5 pack assorted 10x10 squares. Cut to fit. They also work great for using as a gliding material for vinyl wrap on cheap squeegees.
  • Rrusse11
    Rrusse11 Posts: 116
    Thanks all for the comments and input. Clearly there is no "one size fits all".
    Parts Express has a cheap set of 1/2" spikes I'll try in the interests of experimentation
    with my situation and setup. Certainly not as pretty as the Adona offerings, but I'm sure the effect is the same.
    Cheers gents!
    SDA SRS 2.3s
    Pair of Carver TFM 35s
    Carver C-1 Preamp
    CAL Icon MkII CD
    RTA 12s, need major work
    F1nut Posts: 51,941
    Rrusse11 wrote: »
    Cheers gents!
    I'd recommend getting bigger spikes for those 155 pounds speakers.
  • Rrusse11
    Rrusse11 Posts: 116
    Rrusse11 wrote: »
    Cheers gents!
    I've been thinking about that, looks like the PE offering ends up with a 5/16" bolt.
    Contemplating some 1/2" threaded rod and fender washers top and bottom with
    appropriate nuts. Grind/lathe a point on a 2"- 3" section of rod. That should be beefy enough.
    Thanks for the recommendation!
    SDA SRS 2.3s
    Carver C-1 Preamp
    CAL Icon MkII CD
    F1nut Posts: 51,941
    Shakes head.....walks away
  • Schurkey
    Schurkey Posts: 2,122
    The "spikes" on the bottom of my 1Bs are Grade 8, 1/4-20 bolts, with the heads cut off, and the shank sharpened to a point on a bench grinder. I added large-diameter washers against the cabinet, secured with a jam-nut. My labor and <$5 in materials. They sit in T-nuts poked into the base.
    Some Polk speakers already have threaded inserts, buy bolts to match the inserts.
    pitdogg2 Posts: 27,220
    his would be the 1/4 x 20 T-nut in the bottom.....
  • Rrusse11
    Rrusse11 Posts: 116
    My 2.3s already have feet installed, easy to glide them on once upright. I'm thinking along Shurkey's method, get 'em in place and then bring the threaded spike down.
    Ez to lift the speaker vertically an inch or so on a block. Wind the spike to suit the surface. For a hard floor with a puck you only need to extend 4-5mm. Thick carpet may take 20mm.
    Just having them on the heavy tiles has made a difference acoustically. Better bass
    articulation, brought the mids forward. Hmmm, sounds like what F1's talking about.
    SDA SRS 2.3s
    Carver C-1 Preamp
    CAL Icon MkII CD
