Spikes vs Slabs
So the initial plan was to put a set of spikes on my 2.3s. However when dealing with ~150#s
of speaker on a set of nails, and moving them around, it was clear that the situation was fraught with potiential floor damage. It's not like they can be easily lifted off the ground and plunked down somewhere else.
So this morning I went trolling through the local shops and came home with a pair of Turkish travertine tiles, 16"x14"x1 1/8" for $40. The speakers already have a round metal foot on the bottom, which works great for getting them off the ground, and easily skidded on carpet for placement adjustment. It was a simple matter to walk them away from the wall
and place tile, walk the speakers back up onto the slabs. I'll get around to bevelling the edges and corners for appearance.
With the paver/tile underneath they now sit on a "dead zone". Hard to say if I'm not just deluding myself, but it's sounding better, more detailed and discrete.
Cheers!
SDA SRS 2.3s
Pair of Carver TFM 35s
Carver C-1 Preamp
CAL Icon MkII CD
RTA 12s, need major work
  • Rrusse11
    Rrusse11 Posts: 116
    Plinth Placement, say that 3 times fast. {:o)
    SDA SRS 2.3s
    Carver C-1 Preamp
    CAL Icon MkII CD
    F1nut Posts: 52,005
    Your speakers are still decoupled from the floor, which is exactly the opposite of what you want and the reason to use spikes.
    agreed here....when in doubt, spike it baby.
    They make little saucers to put under the spikes if your worried about hard wood floors.
  • Rrusse11
    Rrusse11 Posts: 116
    Ohhh, I thought the idea was to seperate it from the floor, not tie the speaker to it.
    I'll stand corrected.
    SDA SRS 2.3s
    Carver C-1 Preamp
    CAL Icon MkII CD
  • Schurkey
    Schurkey Posts: 2,122
    Spikes couple.
    Little saucers de-couple.
    txcoastal1 Posts: 13,519
    Sealed speakers prefer decoupling
  • verb
    verb Posts: 10,176
    txcoastal1 wrote: »
    And the battle begins! Getting my popcorn! :smiley:
    edited March 2018
    verb wrote: »
    txcoastal1 wrote: »
    Let me clarify---
    I do not consider a speaker with a passive radiator a sealed speaker
    One more clarification, sealed speaker that's not on slab
    While building sealed speaker design, sitting on slab the speaker produced great bass.
    When the speakers were placed on a 2nd floor or a sub-floor foundation, "coupled" the bass energy and sound was driven into the foundation
  • verb
    verb Posts: 10,176
    Somehow the popcorn isn't tasting as good anymore! :smiley:
    pitdogg2 Posts: 27,325
    verb wrote: »
    Is Russ there? That might not be butter.....just sayin
    verb wrote: »
    Sorry :)
  • Rrusse11
    Rrusse11 Posts: 116
    Lawdy! Different opinions,,,,,,,,,,, who'd a guessed?
    "Sealed speakers prefer decoupling " txcoastal1
    Well I got 'em sealed alright, H-nuts and a good (thin) bed of a mortite equivalent.
    "Spikes couple. Little saucers decouple." Shurkey
    My thoughts exactly.
    Which brings us to why I would want to tie into my floor? With each channel having it's own sub (another contentious issue I'm sure), I'm not lacking for bass. I'm looking for just the speakers producing the music, not the house.
    @verb, When your Tnuts arrive I might have to try spikes vs the slab. Perhaps spikes on slab? Slab on wooden floor? (currently on carpet). Spikes through carpet?
    With so much of this "audio experience" being subjective, and the host of variables involved, the only path I can see is to try it all and see what I hear. {;o)
    Certainly with Bonnie Rait running, the bass is beautifully articulate. I did tweak the EQ, more bass and high end treble, mids dialed down a bit, ie. flatter overall.
    SDA SRS 2.3s
    Carver C-1 Preamp
    CAL Icon MkII CD
  • verb
    verb Posts: 10,176
    @Rrusse11 that is weird. I dropped em off on Saturday. Just checked the tracking number and they have not left the UPS store! Hmmm. Let me give those guys a call tomorrow.
    Rrusse11 wrote: »
    Bingo, nothing set in stone, to many variables especially rooms and room treatments. Moving a coffee table or a couch etc can change a room. Slide down in your listening position, or sit up.
    All different
  • Rrusse11
    Rrusse11 Posts: 116
    @txcoastal1,
    Ok, definitions in order. It's a piece of travertine, semi-amporphous limestone I believe. Not what I would define as resonant, mebbe 25#s worth under 2 speaker.
    Not a foundation slab as in 4-6" of reinforced concrete.
    On the PR, my understanding is that essentially the Polks are a sealed acoustic suspension system. The action of the drivers, through air pressure, drive the PR.
    @verb, You need butter AND a sprinkling of some of my 8yr old cheddar to bring that popcorn alive my man!
    SDA SRS 2.3s
    Carver C-1 Preamp
    CAL Icon MkII CD
  • Rrusse11
    Rrusse11 Posts: 116
    "All different"
    Vive la difference! Let alone aging ears,,,,,,,,
    SDA SRS 2.3s
    Carver C-1 Preamp
    CAL Icon MkII CD
    audioluvr Posts: 5,987
    Rrusse11 wrote: »
    Oh boy here we go...
  • Rrusse11
    Rrusse11 Posts: 116
    @audioluvr, yeah,,,,,,,,,,, getting the shield up to deflect the rain of arrows.
    SDA SRS 2.3s
    Carver C-1 Preamp
    CAL Icon MkII CD
    Tony M Posts: 11,728
    F1nut Posts: 52,005
    A speaker with a passive radiator is NOT an acoustic suspension speaker.
    Spikes are used to transfer cabinet vibrations to the floor in turn cleaning up the mid-range and tightening the bass response.
  • GlennDog
    GlennDog Posts: 3,158
    So mini-saucer/floor protectors (under spikes) do not reverse the affect? They still bond with floor?
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • Rrusse11
    Rrusse11 Posts: 116
    "Spikes are used to transfer cabinet vibrations to the floor in turn cleaning up the mid-range and tightening the bass response. " F1nut
    Thank you sir for the detail as to spike purpose. So it dampens extraneous cabinet
    movement or resonances?
    SDA SRS 2.3s
    Carver C-1 Preamp
    CAL Icon MkII CD
    F1nut Posts: 52,005
    GlennDog wrote: »
    The spikes are like an energy transfer conduit, so with the discs the energy is transfered to them and then the floor. Some discs have a thin felt pad on the bottom, which is fine. I've seen others with a thick carpet like pad, which somewhat defeats the purpose of using spikes, so I'd avoid those.
    F1nut Posts: 52,005
    Rrusse11 wrote: »
    Yes.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    What are some spike model recommendations for a pair of SDA 1Cs?
  • afterburnt
    afterburnt Posts: 7,892
    GlennDog wrote: »
    What about miniaturized rubberized pads?
  • verb
    verb Posts: 10,176
    I'm using these from PartsExpress:
    1.25" Diameter at the base and 1.5" tall
    F1nut Posts: 52,005
    Ray, if not on carpet Track Audio spikes at Music Direct are very high quality as are the matching floor discs. However, they are not long enough for most carpet and therefore will not pierce through to the underlying surface. For larger spikes I like the Adona Multi-Element cones. Adona also has a number of other spikes available.
    F1nut Posts: 52,005
    afterburnt wrote: »
    GlennDog wrote: »
    Those would decouple instead of couple.
  • afterburnt
    edited March 2018
    afterburnt wrote: »
    GlennDog wrote: »
    Well I'll be damned, that's all I had to set the disk on the wood floor. I was sweating like a slave wrestling with the speakers to place those damn disk without messing up the floor! Where would one find little felt pads?
    Maybe this is why they don't sound so good?
