Do USB cables make a difference?
gudnoyez
Ok don't want to start a big controversy but do they? A simple yes or no will do. I'm sure some of you have spent more than what these Wireworld Starlight 7's cost, but I'm going to find out if these are any better than the Audioquest Forest ones I own along with some other ones, only have been listening a couple hours with the Starlights and I'm noticing a difference, I'm hoping it's not the placebo effect, but so far the 1's and 0's are sounding better coming out of these red cables, after a couple of hours of tunes and beers.
No experience here, but too many others whose opinion I generally trust feel they do.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
People around me say yes
I’ve never triedMagico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
What's a USB cable?Political Correctness'.........defined
President of Club Polk -
The blue and green ones sound better.
Red not so good.....
Haha -
It's not about the data - its about the noise that travels through the system. A digital cable is still an analog cable. How the DATA is transmitted doesn't matter as much as how the NOISE is transmitted.
I thought the Platinum Starlight was such a great investment (one of the best my system has seen) that I now own three of them.
I bought these cause you did not sell me yours Skip.
quote="Joey_V;c-2389479"]People around me say yes
I’ve never tried[/quote]
Ha I bet when you do try Joey they will cost 3 times what these Starlights set me back want to hear a report when you do.Home Theater
Polk Audio Boom Swimmer, Polk Audio Urchin -
I would imagine they do.....if other digital and analog cables do.HT SYSTEM-
lsi 9's -
I have yet to try a USB cable that made me take a step back and wow me...
I'll let ya know later this week . . . I'm expecting a WW cable . . . very soon
Tho, it will need running-inAC Regenerator PS Audio PerfectWave Power Plant 10
Source Lumin U1 Mini into Lampi Baltic 4
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Not to flame, but wouldn't an optical be better? Hard to transmit EMI noise through photons...
I think part of it is the optical has no ground.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
I have found zero difference in USB cables.
I have five or six usb devices so have tried several cables. Upgrading from basic definitely improved my den and study sound, beginning with the Wireworld UV, WW Starlight Red, AQ Carbon, and WW Starlight Silver. The first two added an organic and more 3-dimensional quality. The Carbon is well thought of, but just didn't do anything special for me. Beyond those above, I have found (varying degrees of) improvement in detail retrieval and frequency response and sometimes a
slight frequency emphasis.
These vary quite a bit in price, but ones I like most are: Lush, WW Starlight Platinum 7, Curious Cable, and DH Labs Mirage.
I would encourage folks to pick one within budget and give it a try to see firsthand.Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Schiit Yggy * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
What would you rather have a $2200 dac and a $100 cable or a $1600 dac and a $700 cable?
I don’t know how pricey usb cables are but. If it were a $30 cable vs same price dac, I would take the cable.
If it were a $2000 or $20,000 dac v cable. I would take the DAC. I have heard DAC’s that make a world of difference. USB cables? None to date. Not hating as I do know cables in other areas make a difference.
Cheers -
My favorite of the ones I mentioned is $250 new. Very much worth that to me personally. Dunno re the zero-sum hypothetical. I always seem able to rationalize whenever necessary, hehe. So probably the $2000 dac and then HAVE to get a good cable. To me, "It all matters" includes usb cables.Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Schiit Yggy * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Well running this Starlight since yesterday zero dropouts, or digital clicks or pops, using a run of the mill USB cable or a amazon one I would experience those issues on occasion, so I guess spending a little bit of money on a good cable is worth it. I was considering a Audioquest Jitterbug, or a IFI Silencer, no longer needed running this Starlight 7.Home Theater
USB doesn't offer an optical flavor that I know of. The digital output of something would but this isn't it.
IMO... a digital output in optical, in theory, should be better (ground has no bearing on that). But you've now introduced two transceivers, one on each end. So electrical impulse to light - across the fiber - back to electrical impulse. If the transceivers putting light on the fiber and then taking it back to electrical suck or are bad or are dirty or the fiber has fractured or... It's just one more thing in the signal path and you have no control of that at all. If you're going to run that signal 1000 feet strapped to a 440vac 3 phase I'm all in. I've been through optical and prefer, by a long shot, the copper lines.
Soapbox put back under the desk.Aaron
Enabler Extraordinaire -
Atkinson and McGowan discussed noise as a principal issue with optical and they linked it to lack of ground, beyond that i have no personal experimentation that would lead me to believe its inferiority or superiority.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
Who cares about theory or on paper. Try it out and experience it. Theory or on paper should not command you like a master. Or does it?
Not me. -
Well, my parents used to ask me if I was going to stick my hand in the fire to see if it is hot. FYI, it is.Lumin X1 file player, Westminster Labs interconnect cable
Haha. I will be doing lots of traveling soon. Bud, you happen to be one of my cities. Would love to have some drinks! And touch them Magicos. Haha
Cheers. -
Sure. PM me when you have a date. Didn’t you grab my free LSi15s, LSiC, and Oppo in 2016?
Not me.
Agreed.
I have learned that theory in this hobby doesnt exactly translate to results.
As I said, I have not tried to compare with reasonable sweat equity various digital cables against each other to make a personal assessment. I can only repeat what others have said with regards to certain digital interconnects, etc.
Yep. Paid almost $1000 to have them shipped to me. And then I gave them all away.. All of them.
It was a awesome karma you did. I passed it all along on my dime after. -
Not me.
Agreed.
My response was not towards you but my experience with USB topic, in general. Much respect to you from me.
Cheers
Great. I hope the new owner enjoys them. I know I did.
