Speaker jumper cables
firsttimer
in Speakers
So is replacing the stock plates on my S60 speakers with jumpers worth it or can I just use the same speaker wire and cut sections and connect these wire to wire without spades on the back speaker posts. Is there any real advantage to doing this.
firsttimer wrote: »So is replacing the stock plates on my S60 speakers with jumpers worth it or can I just use the same speaker wire and cut sections and connect these wire to wire without spades on the back speaker posts. Is there any real advantage to doing this.
Hello @firsttimer generally the stock plates are inferior than jumpers you can buy from a lot of audio cable sellers. Lots of choices out there. I would research the many threads in CP on speaker cables. Lot's of voices on that subject.
I would venture to say that if you're just replacing the stock plates with generic speaker wire (depending on what kind of wire you're currently running) - not much if any benefit.
Again if you go down the cable rabbit hole, as I have done recently, plenty of choices with folks claiming many benefits.
I just swapped out my home brew cables (10ga wire, soldered ends, bannans jacks) with a set of MITAvt's bought here on CP and immediately noticed an improvement. Most notably the bass response. I am now a cable believer!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Do you have any spare/leftover wire? Try itSamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
Yes I have left over wire so going to try it today maybe and see what happens. Should not take long to do it.
Good copper wire is a much better jumper than the gold plated brass jumpers most manufacturers use. Try the wire and if you notice an improvement, then you might want to get yourself a set of jumpers. We can fix you up if you decide to go that way.
Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
I usually use bare (no terminal) speaker wire. When I have speakers with bi-wire connections I approximate the length, add 1/2 inch, cut the sleeve, slide it up and leave enough for the other terminal. Use that space of bare wire to wrap around the other terminal.
Make it Funky!
Well, well, well....who left the door open?
Ok so are there any jumper cables you would recommend that will not break the bank. North of the border so can order through eBay. Maze audio comes up nut not sure if those are any good. Looking for suggestions. Thanks
Ebay has a set of WireWorld Oasis jumpers right now for 75 bucks. I've run the Oasis IC cables in my rig. A decent upgrade IMO.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Thanks will have a look
yupfirsttimer wrote: »So is replacing the stock plates on my S60 speakers with jumpers worth it(?)
YUP!! If you back out the red & black of the BPs, you’ll see a hole. A 6” piece 12 or 14 ga will do it. That’s all I did.firsttimer wrote: »can I just use the same speaker wire and cut sections and connect these without spades on the back speaker posts?
Doing the above? Yeah you’ll save $75!firsttimer wrote: »Is there any real advantage to doing this?
Well thanks for all your input I just put in a pair of audioquest silver jumpers. I must say there is a definite difference in sound quality I think bottom end and top end is more defined than before. Even midrange if that is possible. Time for a speaker wire up grade I see could be in my future lol if the jumpers did that can only imagine what a good set of audio quest speaker wires will do.
Lots of threads here on speaker cable. Hold on tight!
Yes I have been looking. I have a local store that I can by audio quest speaker cable from by the foot then attach banana plugs. We will see what happens lol
A pair of MIT terminator 4’s just popped up here on CP for sale. Smoking deal!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
There's also a nice pair of Audioquest speaker cables in the classifieds. Much better than the by the foot stuff.
North of the border in Canada so need to look closer to home thanks though
I can order audio quest type 4 speaker cable from an online Canadian vendor. 4 foot sections with the banana plugs. Is this good speaker wire
firsttimer wrote: »I can order audio quest type 4 speaker cable...Is this good speaker wire
I've been using those for a while and really like them, but that's just me talking.
Joey_V just got some new ones in that huge FedEx shipment he posted on recently. And he's the kind of guy who spends $$$ on power cables.
Before you order, why don’t you PM me and see what you need from my little stash?Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
firsttimer wrote: »Well thanks for all your input I just put in a pair of audioquest silver jumpers. I must say there is a definite difference in sound quality I think bottom end and top end is more defined than before. Even midrange if that is possible. Time for a speaker wire up grade I see could be in my future lol if the jumpers did that can only imagine what a good set of audio quest speaker wires will do.
Well maybe you're enroute towards some silver AQ speaker wire... wink wink.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
firsttimer wrote: »North of the border in Canada so need to look closer to home thanks though
Being south of the Canadian border never stopped me from buying anything in Canada. -
And I have sold several items here and on audiogon that went up north. Lots of folks here would be willing to ship at cost, and many cables you might find here can fit in a medium size USPS priority box...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
You have bi-wire cables by the looks of it, why did you order jumpers ? You don't need them.HT SYSTEM-
lsi 9's -
@ Firsttimer:Do you have any spare/leftover wire? Try it
Did you get around to trying leftover wire?If so, better(?) Different? No change?firsttimer wrote: »Yes I have left over wire... ...[I’ll*] try it today maybe and see what happens.
Also those AQ jumpers, they just feed the mids & tweets, connected by the lower speaker BPs? In others words the existing wire between the woofers and the amp or AVR?
I actually installed audio quest silver jumpers and have the normal speaker wire hooked up to the lower poles on the speakers. Doing this I have noticed a slight improvement in souls from kids and highs And highs. I have the S60’s crossed at 80 hertz using two Velodyne subs
Did you get around to trying leftover wire, BEFORE installing the AQ jumpers? If so, better(?) Different? No change? The existing wire between the woofers and the amp or AVR are the same when you started this thread?firsttimer wrote: »Yes I have left over wire... ...[I’ll*] try it maybe and see what happens.
Boy I'm confusedfirsttimer wrote: »Doing this I have noticed a slight improvement in souls from kids and highs And highs.
A tad too high me thinks. -
I would be to lol. Improvements in mids and highs lol.
No did not use speaker wire. I removed factory plates and installed the audio quest jumpers instead.
