Anyone familiar with these Dynacos
Can’t get the grills off. How do I get inside?
HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5
  • Easy Runnin
    They are 15 x 8.5 x 8
  • verb
    verb Posts: 10,176
    They look like A25's ? Looks like the grilles are glued on.
  • verb
    verb Posts: 10,176
    Some have used a putty knife to pry em off, but of course you have to protect the veneer. Does not sound like fun. :(
  • maxward
    maxward Posts: 1,729
    Probably A10 instead of A25. The size seems too small to be the A25. Also don’t recall wall hanging brackets on the back of my old Dynacos. Try an extra pair of hands, four putty knives and a little prayer.
  • Easy Runnin
    Yup, they are A10s. The Dynaco badges are glued to a screw ( I found this out the hard way). After unscrewing the badges you gently pry them off. There are small pin in the remaining 3 corner holding the grill on.
    Besides numerous scratches in the veneer tobacco stained grill cloth and lots of dirt they seem pretty good.
    Any suggestion on the veneer and grill cloth would be appreciated.
  • verb
    verb Posts: 10,176
    You could put new veneer right over the old stuff with no issue. The veneer is so thin it would match up pretty nicely to the front edges.
    Hey another thought on removing the speaker grilles. I read that someone used drywall screws (after blunting the pointed ends) through the grille frame. You need small pilot holes through the grille frame for the screws to cut in. Keep driving, then the blunted ends would act like a "pusher" tool, reacting off the driver mounting surface, to lift the frame off the glue. Alternate pushing locations (corner to opposite corner, e.g.), and of course go slow and be careful. Kinda like the opposite of a gear puller. FWIW.
