Can I use a 2 amp wall wart in place of a 1 amp?
Or will I fry something?
  • verb
    verb Posts: 10,176
    You have to check the item that you're powering. It will have the power rating that is recommended. I've used higher current AC adapters on stuff, but only slightly higher than what was recommended, maybe 10-20 percent.
    Double the input current is risky, IMHO.
  • FestYboy
    FestYboy Posts: 3,861
    That's not how current works...
    As long as the polarity and voltage are correct, the current capacity of the wall wart doesn't matter as long as it is at least the minimum required by the item being powered. It's just like amplification: an amp can be capable of 30A to your speakers, but it's not supplying it all the time, only when needed.
  • afterburnt
    afterburnt Posts: 7,892
    FestYboy wrote: »
    I was thinking that it is the current draw that's important not the spec output of the wart. Is this true?
  • FestYboy
    Correct. You pull amps, you push volts.
    mhardy6647 Posts: 35,050
    edited February 2018
    Yes, but of course, if some situation were to develop that would cause the current demand of the powered device to soar, the higher current (higher power, since P = E * I and E is constant) wall wart might cook the device if it could deliver more current than the device could handle.
    In such a case, think of your 1A wall wart as a fuse. Suppose a failure of some kind in the powered device causes it to try to draw 10A. The little wall wart will deliver all the power it can, either limiting the current available to the device or the wall wart itself will die trying.
    A 2A supply will do the same, but will deliver 2A (maybe 100% excess of the device's rating, or more) until one or the other dies.
    Not trying to use scare tactics -- heck, I'd do what the OP's proposing if I had the hardware & the inclination! -- but thought it worthy of mention.
  • FestYboy
    Very true Doc, my posts above are assuming everything behind the wall wart is working properly and remains stable. It would be ideal that the unit in question is fused at 1A after the wall wart. Any failure would then blow the fuse and save the power supply.
    Viking64 Posts: 7,566
    This is the first time in my life (53+ years) that I have ever heard the phrase "wall wart".
  • mdaudioguy
    mdaudioguy Posts: 5,165
    Viking64 wrote: »
    Not uncommon: https://www.pcmag.com/encyclopedia/term/60246/wall-wart
    I think that Viking64 lives -- how to put this diplomatically? -- a little off the beaten path.
    Even compared to me.
  • verb
    verb Posts: 10,176
    I too admit never heard of an AC adapter referred to as a wall wart. :smiley: But consider me now edified!
  • afterburnt
    I heard it before and they don't let me out much.
    Actually, I have to disagree. I don't peruse stereo-related websites, but in the grand scheme of things, that isn't the "beaten path" as far as the internet in general goes. It seems most of the people here are in a niche area and are oblivious to most of what else is happening online. :p
    pitdogg2 Posts: 27,077
    Viking64 wrote: »
    wait! what? there is more than this out there ???
    brain explosion.....
    Settle down, Beatrice, or you might lose your earrings in the explosion. :p
    Viking64 wrote: »
    The term came into wide/general use in the computer (laptop) and cell phone/portable audio realms -- video games, too. Consumer electronics went to outboard power supplies big time in the 1990s, and external transformers, which quickly came to be known as wall warts, proliferated. Laptop P/S, in the early days, were often called bricks -- I've got some pretty brick like Dell P/Ss around here, too.
    I've heard the term "brick" quite a bit. Never "wall wart", though. And it's not like I am denying its existence. HAHAHA
    That's good -- although wall warts are just a theory...
  • steveinaz
    steveinaz Posts: 19,545
    YES. As stated, as long as the current available meets the minimum necessary. Current is "potential flow" not something that is supplied at a fixed rate.
