Need help fast with broken amps
Codey
Codey Posts: 188
edited November 2004 in Electronics
I have a chance to buy two audiosource amp ones for about $60. The catch is they need servicing. The guys says they power up but the only put out muffled music with noise. Does anyone have a clue what might be wrong with them. Are they worth buying?
Outlaw 950
GFA-555
GFA-545
GFA-2535
RTi8s
CSi5
FXi3s
214L Vented Tempest
250w BASH amp
Toshiba HDA1
Toshiba 44" DLP
NAD 533 Turntable
Tripplite HT3100
Xbox 360
Post edited by Codey on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    You can buy NIB Amp100's for $100 on ebay.
    Cheers,
    Russ
  • Codey
    Codey Posts: 188
    Thanks, I'll pass.
    Outlaw 950
    GFA-555
    GFA-545
    GFA-2535
    RTi8s
    CSi5
    FXi3s
    214L Vented Tempest
    250w BASH amp
    Toshiba HDA1
    Toshiba 44" DLP
    NAD 533 Turntable
    Tripplite HT3100
    Xbox 360
  • stereo55
    stereo55 Posts: 418
    I agree with Russman ,
    There are much better deals on AudioSource amps that can be had with a little searching .
    Look at E-bay for starters , or possible check Ubid.com or at Thetwistergroup.com .
    I purchased an Audiosource amp (refurbed) from Ubid that works great ; and a another used amp from a fellow Polk member here at the forums . No regrets thus far ..... ;):D
    SDA-2B's ~ Pair SDA-CRS's ~ ,*** Main listening: Maggies MG1 ~ Polk SDA 2B's ~ Monitor 10's , 3-pairs (2 pairs moded into SDA's w/SDA-2B/CRS cross-overs) , * DCM TF600's * Mission M71/M72 *** Main brdrm FRT: RTiA-5's /Presence RTi-4 / LSI-704 Cntr / Rear FXI3's ~~~ Assorted Main listening rm : , 2- Heathkit W-5M /tube mono blocks (Parasound P/HP-850)* * 2- Altec Lansing 1590b's/mono blocks (Yamaha C-45) * CM Labs 35D * Dynaco ST-70 ~ Occasionally ~* Yamaha CR-820/A-760 ,* Sansui AU-317/AU-217 * Carver 900 rec *2-Dynaco ST 120* 1 Hafler DH-220* Marantz 1040 ... more
  • kingtut
    kingtut Posts: 813
    Codey, get the Audiosource Amp 3. I've been using one for about a year, and it works great. There is one test by one of the on-line magazines, and it rivals one of the more powerful Carver amps.
