by specs which is better
Willow
Willow Posts: 11,231
edited November 2004 in Speakers
for rears do I continue using my r10's or swap thm out for Jbl e20s
I have both at home just not sure wich ones to use right now the polks are in and I have not tried the JBL's in my new set up.
thanks
Post edited by Willow on
    VR3 Posts: 29,427
    If you have BOTH there, why not switch em out and play the same thing over and over again to see if you hear a difference.
    You cant really go by specs since not every company measures them the same
  • Tour2ma
    Tour2ma Posts: 10,177
    Speakers are the one piece where specs are near completely out the window. Yes, paying attention to impedance ratings and efficiency can help you avoid a mismatch with your existing electronics, but they cannot tell you a thing anout how they will sound.
    Do as Sid suggests and swap and listen and repeat as needed.
    More later,
    Tour...
    Vox Copuli
