by specs which is better
for rears do I continue using my r10's or swap thm out for Jbl e20s
I have both at home just not sure wich ones to use right now the polks are in and I have not tried the JBL's in my new set up.
thanks
thanks
Post edited by Willow on
If you have BOTH there, why not switch em out and play the same thing over and over again to see if you hear a difference.
You cant really go by specs since not every company measures them the same- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Speakers are the one piece where specs are near completely out the window. Yes, paying attention to impedance ratings and efficiency can help you avoid a mismatch with your existing electronics, but they cannot tell you a thing anout how they will sound.
Do as Sid suggests and swap and listen and repeat as needed.More later,
Tour...
Vox Copuli
