SDA Passive Radiator SW-120
I'm doing some storage spring cleaning and getting rid of some pieces and parts I don't have any foreseeable use for... found an SW-120 I had as a spare for some SDA 2's. This PR is the 12" kind with the thicker foam disc, used I believe in all the SDA 1's and the first gen SDA 2's (not the 2A's or 2B's). It looks like it's still in great shape with none of the blistering that sometimes happens on these.
If anyone has any use for it, let me know and it's yours for the low, low price of free, plus shipping. If interested, just PM me your zip and I'll look into what it would cost to ship it.
    EndersShadow Posts: 17,704
    If it works for SDA 1As then I will take it.
  • FestYboy
    FestYboy Posts: 3,861
    I'll step in line next if it doesn't work out for @EndersShadow
  • Wow, more popular than I thought... first PM by timestamp was TNTsTunes, Enders is next... I'll box it up and see what shipping will run.
  • verb
    verb Posts: 10,176
    Did the SW120's come in different variants??? I have PR's labelled SW120 in my 1C's that have the thinner disc (no foam), and a weight in the styrofoam piece. Both PR's are the same, labelled SW120. Anyone have an idea???
    Reference post for surround repair that I am pursuing on one of my PR's:
    http://forum.polkaudio.com/discussion/180261/pr-surround-repair#latest
    BTW great Karma @On3s&Z3r0s
    F1nut Posts: 51,761
    Yes, the same model came in two versions.
  • verb
    verb Posts: 10,176
    Thank you @F1nut I'm assuming they are interchangeable but must be a match set if they are to be replaced. Correct oh guru?
    pitdogg2 Posts: 27,040
    Yes i would make sure they match. My take, the foam was heavier so no need for the weight. Some of the first sets with the foam front bubbled badly so i believe they switched to the harder plastic like front and so those would behave the same they added the weight in the rear part. I've used both on my SDA1 signatures. The first set had foam and bubbled a bit. I found no difference in bass response.
    F1nut Posts: 51,761
    verb wrote: »
    Probably best.
  • This is definitely the earlier kind with the foam that sits proud of the surround by maybe 3/16" of an inch or so.
  • verb
    verb Posts: 10,176
    Thanks @pitdogg2 and @F1nut always appreciate it!!!
  • This one's on its way to its new home. Thanks, everyone!
