PR Surround Repair
Please see below.
Just starting to de-laminate a bit, but wanted to fix it before re-instlall into my 1C's. Please advise and opine. Thanks !!!
http://forum.polkaudio.com/discussion/179960/another-1c-upgrade-path#latest
    F1nut Posts: 52,166
    Some of that bike inner tube adhesive should do the trick. I'd protect the disc somehow to prevent any from getting on it.
  • verb
    verb Posts: 10,176
    Thanks @F1nut !!! I seen that mentioned in older posts, but wanted to get confirmation from the guru(s) ...
  • 20hz
    20hz Posts: 636
    I like 2 part epoxy for repairs , it dries fast and is flexible .it would be a smooth repair if you could use one of those cheap plastic clamps to hold it flat , just be careful not to glue the clamp on to it .
    F1nut Posts: 52,166
    If your 2 part epoxy is flexible after curing the hardener has gone bad or you need a different brand of epoxy. It should cure rock hard.
