Hankering for Larry's Spikes
Looking for some spikes to secure the 1C. Got carpet in the basement, short pile.
I seen some of the images of the spikes that Larry has made. Beauteous !!! Sadly, I have not heard of any future production runs on those :(
Decent reviews of the Dayton 2-Piece spikes in this forum. I like the idea of a 2-piece design and have the ability to level the speaker cabinet if needed.
And as always, I missed out on the smokin deal @Toolfan66 on those spikes back in June !!!
http://www.daytonaudio.com/index.php/dss4-g-gold-speaker-spike-set-4-pcs.html
Just for the record. Uh, no, I will not use the below per @lightman1 recommendation.
    pitdogg2 Posts: 27,328
    edited January 2018
    Do the 1c have a threaded T-nut now? Those at parts express are metric and will not work in the T-nut. I just bought some exactly like those. I have it bookmarked at work. I'll send a link if you like
  • verb
    verb Posts: 10,176
    No T-Nut now, but I was thinking about using them on my new bases. The originals were just glued and stapled.
    I noticed the kit comes with a threaded insert (H-Nut). Anyone use those?
    Sure please send link. Thanks!!
    mhardy6647 Posts: 35,238
    I've gotta say, reading this thread's title via "New Posts" and sans context kinda had me a little worried.
  • verb
    verb Posts: 10,176
    @mhardy6647 you've been in the "gutter" thread a bit too long ... :)
    Toolfan66 Posts: 18,189
    I have never done a run of spikes to sell, but after I made some stainless ones, I let go of a couple sets of my brass ones..
    I have no plans to ever do a run of them..
  • verb
    verb Posts: 10,176
    Toolfan66 wrote: »
    Dang. Thanks for letting me down easy ... BAM !!! :)
    Those nuts IMO suck. I will most certainly send you a link
    msg Posts: 10,472
    edited January 2018
    nothing to see here, move along
    Post edited by msg on
    Viking64 Posts: 7,627
    Back in 1991, TBS used to air episodes of "The Beverly Hillbillies". They had an ad that said: "Jethro. Everybody has a hankerin' for him, but only TBS has a heapin' helpin' of him." :p
    Teach me how to edit a post with nothing Scott.
    F1nut Posts: 52,006
    Look closer Ivan.
    "nothing to see here, move along"
    edited January 2018
    On a phone i can only get so close Jesse.
    lol
    Only so much i can see and do on a 4" screen :#
    edited January 2018
    https://meniscusaudio.com/product/long-mirror-image-pts-gold/
    Now you will get a discount for buying 8 I believe it works to 56.00 for those above and less for those below.
    Look around the site, I bought these because I had the smaller points at home so if they were too tall I could switch them out.
    https://meniscusaudio.com/product/mirror-image-pts-gold/
    On past speakers I drilled a 1/4" hole through the bottom of the speaker. I then used a 1/4" fender washer under a the 1/4" grade 5 or 8 bolt head. smaller hole and nothing to come out and get tight as needed.
    choose your path carefully. PM me if needed
  • verb
    verb Posts: 10,176
    Thanks @pitdogg2 !!!
