A friend just gave me (gratis) a pair of SDA1's :-)
Newbie here. A friend (original owner) just gave me (gratis) a pair of SDA1's :-) They have the vertical tweeters. They are oiled walnut tops and bottoms and black cloth on the front and sides. I have not yet hooked them up to my Threshold 400A so want to ask about the so-called 'frozen' magnet issue. How can I determine whether these units suffer from any 'frozen' magnet issues. I do not want to try to drive the speakers if any of the magnets are damaged and if doing so will damage the woofers or systems. Also, if I need to purchase any new woofer drivers what is the contact point at Polk (Tel #?) Thanks !
Best Answer
    Tony M Posts: 11,897
    edited January 2018 Answer ✓
    Push on your mid-woofer cones gently and see if they push in and come back.
    If they do that, you're good till you glue them down later.
    Do you have the connecting cable ?
    Your Threshold Amp. . I don't know if it's common ground or not. Others will chime in to let you know about that issue.
Answers
  • Threshold400A
    Thanks, Tony. I do have the blade/pin cable
    edited January 2018
    Maybe it's discussed deep down in this link. I got tired of looking at a lot of reviews and comments after a while. Don't hook that amp up until you get the common ground issue answered.
    https://forum.audiogon.com/discussions/review-threshold-400a-amplifier
  • TNTsTunes
    TNTsTunes Posts: 751
    Tony M wrote: »
    If the drivers are good/not frozen and the amps common ground issue hasn't been answered don't hook up the interconnect/SDA cable. You can safely use a non-common ground amplifier as long as that cable isn't connected. The speakers will just lack the SDA effect.
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
  • MrBuhl
    MrBuhl Posts: 2,419
    Nice friend!! Congrats!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • agfrost
    agfrost Posts: 2,485
    edited January 2018
    Jay
    @agfrost, Great Links! That was some great reading on a Threshold 400a amp and some insight by the man, NELSON PASS, himself.
    Common Ground amp, for sure.
