Charcoal or fire place users
Found this new @ GW. Fire started in three minutes. They have them on amazon. Works great. Peace D
  • WagnerRC
    WagnerRC Posts: 2,203
    I have the same igniter. Works great with lump charcoal. I really like it.
  • aprazer402
    aprazer402 Posts: 3,386
    Very cool, new ones are not cheap though, about $80.00. Closest thing to a lightsaber! :)
    xschop Posts: 5,163
    Curling iron with a surprise.
  • soundfreak1
    soundfreak1 Posts: 3,414
    I guess I'm just old school I use matches
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • decal
    decal Posts: 3,205
    My pet squirrel usually lights mine !!!!!
  • Jstas
    Jstas Posts: 14,985
    One of those charcoal chimneys is like 10 bucks. On sale they get as low as 6 bucks.
    Expert Moron Extraordinaire
    mhardy6647 Posts: 35,006
    I like the chimneys for starting charcoal fires. Started with a dump find chimney (duh), went through a couple of cheap ones (which worked fine but burned/rusted out quickly). Bought a Weber chimney (which wasn't expensive, either) and it's served well for -- jeez, I'll bet 7 or 8 years now.
    We grille outside a lot (including dead of winter).
    Chimney full of charcoal, little crumpled up paper underneath. Add flame and 20 minutes later, good to go.
  • WagnerRC
    Long time chimney user too. Toys
  • dkfreebird
    dkfreebird Posts: 1,186
    Chimney user too. I use the outer part of the charcoal bag for the paper and by the time I get to the end of the charcoal all of the bag is used up too.
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
