sealed enclosure question
marcpam
marcpam Posts: 228
edited November 2004 in Speakers
All right guys, as you may well know, the mid range on the rti12s are supposed to be a sealed enclosure. The upper portion of the speaker. When you gently press one mid range the other mid range is supposed to go outward because of the sealed enclosure. Well, should i be concerned if my other tower doesn't do that? I am concerned that it will affect performance.
Post edited by marcpam on
  • gatemplin
    gatemplin Posts: 1,595
    Yes in a sealed enclosure when you press in one of the drivers the other should move out. Pull the drivers and take a look.
    Graham
  • marcpam
    marcpam Posts: 228
    what exactly will i be looking for. How would I know if it is properly sealed. I would rather see if polk customer serv. could do anything. These speakers are a few months old.
  • gatemplin
    Maybe a driver is missing a gasket or maybe there is no glue where the driver leads enter the chamber etc. Give Ken a shout and he can help you.
    Graham
  • marcpam
    marcpam Posts: 228
    i pulled both drivers and the leads have silicone and there is a thin layer of gasket around both drivers. It seems that it is a structure problem internally. If i was to send this tower to polk, do you think they will replace it for me. The towers are less than a year old.
  • gatemplin
    Since the problem is nothing obvious contact Ken the man and he will straighten things out.
    Graham
  • steveinaz
    steveinaz Posts: 19,545
    I thought the RTi12's were ported?
  • hoosier21
    hoosier21 Posts: 4,418
    The tweeter and mids have a separate enclosure with the cabinet, sealing them off from the rest.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
