Where are box drawing/dimension plans?
Systems
Systems Posts: 14,873
edited November 2004 in Custom Fabrication
I have been look throught the site for enclosures for 2 12" subs, and found :
http://www.polkaudio.com/car/toolbox/subboxplans/subbox_plan.php?id=47&mesurements=standard
But there are is not an actual drawing w/ dimensions. IS there any on the site that I am missing? Thx
Testing
Testing
Testing
  • Systems
    Awsome!
    Testing
    Testing
    Testing
  • MacLeod
    MacLeod Posts: 14,358
    As far as I can tell, that is all there is. There isnt a detailed drawing but there is plenty of specifications as to measurements and dimensions and such. Take those along with the detailed images and you should be able to piece something together. Plus you can always call Polk customer service for more advice.
